Old 07-08-2013, 09:01 PM   #1
yellow70
yellow70's Avatar
3 inch spacer
If i run a 3 inch wheel spacer on a 4x4 blazer ,can i have normal hub caps ? thoughts welcomed !
yellow70 is offline   Reply With Quote
Old 07-08-2013, 11:10 PM   #2
Joanne
Joanne's Avatar
Re: 3 inch spacer
If you mean a 3" spacer between the hub face and the inside of the wheel, it won't have any impact on how a hubcap fits on the wheel.
I won't venture an opinion about running a 3" spacer...
Joanne
Joanne is offline   Reply With Quote
Old 07-09-2013, 09:57 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 3 inch spacer
Sounds dangerous.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-09-2013, 10:45 AM   #4
70-K5
Re: 3 inch spacer
1.5" is all you need to remove the stagger from the rear axle being shorter...
Also, spacer is bad, adapter is better, adapters bolt to the existing studs and then have their own studs that the wheels bolt to.
Always be sure to remove the wheel and re torque the adapters to the hubs just like you'd check the outside lug nuts.
70-K5 is offline   Reply With Quote
Old 07-10-2013, 01:49 PM   #5
CTENTA1
Registered 1971 K5
Re: 3 inch spacer
[QUOTE=70-K5;6164109]1.5" is all you need to remove the stagger from the rear axle being shorter...
[/QUOTE
70-K5
Is that a 2 piece adapter? I planned on getting some myself but had not seen the type you have. How do they attach to the wheel studs onto the rotor or drum?
CTENTA1 is offline   Reply With Quote
Old 07-09-2013, 04:16 PM   #6
yellow70
yellow70's Avatar
Re: 3 inch spacer
Thanks!!!
Old 07-10-2013, 04:10 PM   #7
70-K5
Re: 3 inch spacer
Just googled the image to illustrate the difference between adapters and spacers. Spacers are typically 1/4" or so for minor adjustments for little car tires.
Old 07-10-2013, 04:47 PM   #8
DANTES JIMMY
DANTES JIMMY's Avatar
Re: 3 inch spacer
Adapters not as bad as they sound just hard on bearings and hubs and knuckles and depending on how much adapter you use and how big your lock out is you may get away with a factory hub cap with no hole
DANTES JIMMY is offline   Reply With Quote
Old 07-10-2013, 04:48 PM   #9
DANTES JIMMY
Re: 3 inch spacer
Ps: Do not use a three inch spacer
only an adapter spacer would be dangerous
Old 07-10-2013, 04:49 PM   #10
DANTES JIMMY
Re: 3 inch spacer
Duallys have been running a front spacer/adapter for years on the front of them
