Old 07-09-2013, 04:41 AM   #1
ozkiwi
Is my diff stuffed?
Jacked the truck up (both wheels off the ground) to look at the the brakes and while i was there playing around I think I Found the clunk that happens when going from reverse to Drive and the other way around.There is a lot of free play in the diff.How do I get rid of it?
ozkiwi is offline   Reply With Quote
Old 07-09-2013, 09:33 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Is my diff stuffed?
hows the ujoints?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-09-2013, 10:51 AM   #3
ozkiwi
Originally Posted by motornut View Post
hows the ujoints?
a little worn but most of the play is in the diff.
Old 07-09-2013, 01:00 PM   #4
willett
Another Day, Another Dollar
willett's Avatar
there will ALWAYS be lash in your diff, if there isn't any you have a big problem.
If there is ANY play in your U joints you should eliminate that, I can almost guarantee you tht whatever noise you are hearing is a result of pooched u Joints
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 07-09-2013, 01:10 PM   #5
Keith Seymore
Keith Seymore's Avatar
There should be around .008-.012" backlash between the ring and pinion in the diff.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-09-2013, 02:19 PM   #6
PAPA KENT
PAPA KENT's Avatar
I agree.
PAPA KENT is offline   Reply With Quote
Old 07-09-2013, 02:41 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
I've had clunks and pings be the joints
have a look at where the ujoints join up can you wiggle and see the gap change?
or does it ride/look off center in the cup?
John
Old 07-09-2013, 06:02 PM   #8
LONGHAIR
It depends upon where the "free play" is coming from, which you can't tell w/o removing the cover.
If the slack is from wear in the ring and pinion gears, replacement is the only option. It cannot be "adjusted" away.
The bearings can also contribute to this, once again, no adjusting to fix. Replacement is the only way.
Also, be aware that all of this is a job best left to a professional. It takes special tools and quite a bit of skill-patience to do it properly. If everything is not exactly right, it will be noisy as a best case scenario, fail miserably soon after.
Pay the money, get the peace of mind of a warranty.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-09-2013, 06:43 PM   #9
Rufton
If rear differential is quite under load at all speeds and gear oil looks/smells normal there is a fair chance it's healthy.
Rufton is offline   Reply With Quote
Old 07-09-2013, 06:59 PM   #10
ozkiwi
There is some play in the Ujoints and for sure it needs new wheel bearing .Will do those and see if that eliminates it and will get a specialist to check it out after that if it is still clunking.
Old 07-09-2013, 07:00 PM   #11
ozkiwi
Does have faint gear whine at freeway speed.
Old 07-09-2013, 07:05 PM   #12
Rufton
Does it have any glitter in gear oil.
Do you have an IR temperature gun to measure operating temperature?
Old 07-09-2013, 07:13 PM   #13
Rufton
6-24-13 after 90 mile trip hauling about 600 lbs load.
Temps according to IR gun:
Rear diff 165F.
U-joints=130F.
3 spd man trans=130F.
Drive shaft=105F.
Ambient approx 85F.
Old 07-09-2013, 07:18 PM   #14
ozkiwi
Yes I just bought one .
Thanks I will check that out.
Old 08-02-2014, 04:08 AM   #15
ozkiwi
Almost a year later and I did nothing about it other than check the U joints which were good. The clunk now is terminal and I got a friend to but it back and forth between reverse and drive and the output shaft moves almost half a turn before the gears engage and I know the wheel bearings are badly worn as well so I figure only the diff housing is useable.
So here is my question.
If I buy a new ring and pinion in the form of a rebuild kit which comes with bearing and gaskets plus new axles and outer bearings and seals is this all I will need?
I think this diff is totally worn out and want to supply everything that is needed to the guys who will rebuild it because you cannot just run down to the auto parts store and buy parts like you can in the US. I want to do it right so there is going to be no revisit to this area in the future.
Old 08-02-2014, 08:32 AM   #16
LONGHAIR
This is one of those "while you are in there" types of jobs. I would get the inner spindle bearings/seals, inner axle seals, and replace the axle joints too. It's a big job, so do it all....once.
Wow, had my head in 4x4 mode on this one.....lol
Old 08-02-2014, 08:55 AM   #17
Jake Wade
Jake Wade's Avatar
It is most likely a combination of worn spider gears, cross shaft, and ring and pinion gears to have that much slack.
Sounds like you need a total rebuild.
Jake Wade is offline   Reply With Quote
Old 08-02-2014, 01:47 PM   #18
Chevy1966
Back to the original question for a minute... I would sure like to know how much rotational play is normal in the diff yoke itself. I have 14-bolt corp diff. With driveshaft disconnected I can rotate the yoke by hand and there is a fair amount of free play, but what is the correct amount in terms of degrees?
Chevy1966 is offline   Reply With Quote
Old 08-02-2014, 05:22 PM   #19
wilkin250r
wilkin250r's Avatar
To the original poster:
I would do some diagnostics and research, first. It should only cost you some RTV and differential fluid, a whopping $20. (AUD is close to USD).
Pull the differential cover off (do a search or ask for the procedure to drain the fluid). Do NOT remove any other components, just inspect the entire assembly, and it's safe to rotate. Try to determine the exact cause and severity of the problem.
Most likely you will need a new ring and pinion, but you knew that already. What you DON'T know if whether or not you'll need new spider gears, new cross shaft, or even a complete new carrier.
In fact, because the procedure is so simple, many reputable shops will often do it for free (plus the cost of new diff fluid), or a very small fee.
In fact, because the procedure is so simple, a reputable shop will often do it for free (plus cost of new diff fluid) or at least a very small fee.
From that point, you can make an informed decision. As long as you didn't remove/change any internal components, you can just reinstall the diff with new RTV, and fill with new diff fluid. For a whopping $20 and some time, you'll be able to determine exactly which components you'll need to order and give to your shop for a rebuild.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 08-05-2014, 07:37 AM   #20
ozkiwi
Went to a differential specialist who open it up with me there and he was amazed it had not let go.Everything needs replacing so I am going to bite the bullet and get a brand new 9 inch built with quality gears,axles etc and will not visit this end of the truck again I hope.Expensive but not a lot more than rebuilding the gm 8.5.
Old 08-05-2014, 07:39 AM   #21
ozkiwi
Old 08-05-2014, 11:50 AM   #22
hatzie
Moderator
hatzie's Avatar
You racing it at high HP? a built 9" is some pretty serious stuff.
You could get a known good condition 12bolt around here for about $100 used that will run for many many trouble free miles.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-05-2014, 03:24 PM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
9" rears are tough. And usually cheaper in the long run.
KQQL IT is online now   Reply With Quote
Old 08-05-2014, 08:11 PM   #24
ozkiwi
Around here is Australia a 12bolt would be a very rare item and go for about $800-$1200 .Just the parts I need to rebuild my current diff from summit racing landed here would be $1200 then I would have to get someone to rebuild it.The 9 inch is overkill for my weak little crate 330hp motor but then again I love this truck and will be driving it till the day I drop at which time the new owner will have a nice rear end he wont have to worry about.The 9 inch works out to be $800 more than any other option.
