Old 07-09-2013, 10:42 PM   #3
themb2g
Re: cruise control switch
Originally Posted by ls1nova71 View Post
Are you wanting something that goes on the column like stock or something else? Sounds like you don't want it on the column, but if you do, I have some that will work on your 72 column. You can also buy a Dakota Digital or other aftermarket lever, but be aware that they are wired the opposite of GM switches, so you'll have to use relays to reverse the switches. The only aftermarket one that you do not need the relays with is the Dakota Digital dash mounted one. The ones I have are GM so it's as easy as hooking up 4 wires to make them work. I have two different styles, one is smooth and one is ribbed and looks similar to the original turn signal lever on a 67-72. I can get you pics if you're interested.
The brake switch you need is 25524848. That is an ACDelco number, but there are aftermarket replacements also
CAn you send me pictures of the two options you dont have to make a new relay for? how much do you sell them for?
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
