Old 07-09-2013, 11:14 AM   #1
cab_01
cab_01's Avatar
Front discs
So in the FAQ section. It says
" 3) The 63-66 a-arms can also be used with any other spindle (71-72 or 73-87) with a simple ball joint change.
* The upper and lower ball joints and outer tie rods must match the correct year of spindle you choose."
So I should be able to go to the junk yard and just get spindles then order the correct year ball joints, calipers and rotors correct?
I have a 65 C-10. This seams to easy. Is it?
cab_01 is offline   Reply With Quote
Old 07-09-2013, 01:32 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Front discs
Yes BUT, with the later outer tie rods, they are bigger threads on the part that connect to the coupler. I believe you need to use an adapter adjuster that has one size on one end and the larger size on the other end. I believe CPP make these, maybe others. Another option is to swap the steering linkage to the same year and use all the tie rods from whatever year you get from the junkyard.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-10-2013, 11:23 AM   #3
cab_01
cab_01's Avatar
Re: Front discs
Thank you, Yes i read about the coupler and forgot to mention it.
