07-09-2013, 03:01 PM | #1 |
question regarding air ride....
Was curious if you run air ride how low will a c10 sit with air completely out of the bags without doing any sort of body drop???
If anyone has pics id love to see them. Posted via Mobile Device |
07-09-2013, 08:48 PM | #2 |
Kill Bill...et
Re: question regarding air ride....
Maybe the mods could move this to the suspension forum for some more responses. Folks are always willing to share pictures. My avatar pic is my '67 with air and no body drop. Just a small notch in the rear. There's some more shots of it in the video at the bottom of my signature.
07-10-2013, 09:53 AM | #3 |
Here's some pictures of my truck. I know it's not pretty, but it'll give you an idea of the difference from stock, to bagged - aired up and emptied.
I'm running the Porterbuilt stage 1 kits both front and back, stock arms & spindles, no notch. Top pictures are stock with stock/original springs. Middle and bottom it's been bagged. Middle picture is aired all the way up (about 80 psi in the front and 50 psi in the back)- higher than ride height. Bottom picture is aired out completely - 0 psi. - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
07-10-2013, 11:44 AM | #4 |
No frame modifications- dropped spindles and bags- Just 17" wheels
Dave aka "Wild" Current truck "Ida Mae" 71 K5 Blazer Former Trucks "Loretta" 71 Longbed (AZ) "Tanya" 69 Stepside (AZ) "Ferdinand" 71 Longhorn (SD) "Patches" 67 Panel (IA/ KY) "Rosita" 68 C30 (KY) Instagram @Wildforwheels @k5_klub @c10university Profile pic provided by Jeff Sundance |
07-10-2013, 12:24 PM | #5 |
67-72 parts collector,…
105 pages of pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=255929 There are many threads about this. You just have to look.
07-10-2013, 01:40 PM | #6 | |
07-10-2013, 03:02 PM | #7 |
Thanks so much matt!!! Im trying to get the body as close to the pavement as possible if i go the air ride route , so ive been trying to understand what limits it from getting there. I looked under the truck and it doesnt seem to have a huge frame hanging below the body of the truck. I dont mind cutting out the fenderwells in the bed and redoing them , front fenderwells.have already been removed so there shouldnt be issues in front I wouldnt think.
07-10-2013, 03:06 PM | #8 |
I am cool with notching the frame on this truck to get as low as possible out back.
So with drop spindles and bags in front itll lay crossmember?? Posted via Mobile Device |
07-10-2013, 11:31 PM | #9 |
Drop spindles and bags will lay the front crossmember, although you may need tubular arms or modify the original arms depending on the wheel and tires you run. Upgrading to a dropmember setup will let the frame lay all the way out, and your pinch weld will be 3/4 of an inch from the pavement. Porterbuilt even makes a bolt in body drop for these trucks that will let you lay pinchweld. Basically, the lower you want to go, the more expensive it is. The bad part is once you start lowering one, you want to go lower, and lower, and lower....
07-10-2013, 11:51 PM | #10 | |
Seth |
07-11-2013, 02:17 AM | #11 |
Thanks Colin ! Love your truck!!
Getting the pinch weld 3/4" from the pavement would be low enough for me. That would.get me the look im going for if I go the route of bagging it. Posted via Mobile Device |
