Old 07-12-2013, 11:32 AM   #26
Howitzer
Re: Need help! Boss 338 fitment.
Looking to pick up a set of these. Just read that the 14 mm et on the 20 X 8.5 (5.25 BS) rub on the inner fender. Is this the size I need? Wil I get away with a 255/45 tire up front? I've got an ECE 2/4 drop. Might go lower in the future with spindles.
As for the back I understand the 20 X 10 with 2mm et would be the ones to get. It's a '72 rear end.
Howitzer is offline   Reply With Quote
Old 07-13-2013, 02:34 PM   #27
Howitzer
ttt
Old 07-13-2013, 06:02 PM   #28
RaceAGMC
RaceAGMC's Avatar
I think u will be fine at that ride height, but if you put a set of spindles on, you will def rub, eps since your tire size is taller than mine. If you ever want to go real low, I would et the ones with even more back spacing.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-13-2013, 07:56 PM   #29
MattPSU
MattPSU's Avatar
Where are the pics with the new wheels?
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
