Old 06-27-2013, 12:50 AM   #376
Captainfab
60-66 Nut
Re: Lost My 65
Let us know what you think of them.
Old 06-27-2013, 02:58 AM   #377
AzCountryman
AzCountryman's Avatar
Re: Lost My 65
Just spent the better part of an hour here at work reading this thread. Awesome job finding your truck. Loved the whole google earth photos. Thats some good hunting. Looks like you are getting some work done to it. Keep it up and Congrats. Now off to read your service truck thread.
AzCountryman is offline   Reply With Quote
Old 07-13-2013, 08:49 PM   #378
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
Took the smaller Shrinking Disc to an area on my hood that had a small dent and some 'Oil-Canning'.
It worked fantastic.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-13-2013, 08:58 PM   #379
LostMy65
LostMy65's Avatar
Re: Lost My 65
Thanks for reading.
It is great having having it back.
I tinker on it when I can.
Old 07-25-2013, 11:10 PM   #380
MisterC
MisterC's Avatar
Re: Lost My 65
I admire your willingness to undertake body work. I have zero confidence in that area. I have a buddy that's great at it, but I'm like number 12 in line to get his assistance.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 08-19-2013, 08:38 PM   #381
step65
Re: Lost My 65
Great story look forward to seeing you bring it back to your own.
step65 is offline   Reply With Quote
Old 08-24-2013, 09:11 PM   #382
jhrusk
Re: Lost My 65
cool truck story,I bought the truck my Grandfather gave me 14 years later after I sold it so it is cool to see your progress
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 08-25-2013, 09:25 AM   #383
Low Elco
Re: Lost My 65
Glad to see this still Movin!
Low Elco is offline   Reply With Quote
Old 08-25-2013, 10:08 AM   #384
Snailed
Snailed's Avatar
Re: Lost My 65
Shrinking with friction discs is great! I do a lot of metal shaping and sheet metal repair at work and I use the big disc a bit. The little one is great if you know exactly where you need to shrink already, the big one will help you find the spots. Have you made or bought a good slapper? I find I grab mine more than any other hand tool when working out dents.
Snailed is offline   Reply With Quote
Old 08-25-2013, 12:11 PM   #385
LostMy65
LostMy65's Avatar
Re: Lost My 65
I do need to get/make me a slapper.
I do have a leaf spring I can make one out of.
I plan on attacking the body panels this winter.
I'm anxious. to get started.
Right now I'm working on getting some concrete down in my pole barn.
Old 08-25-2013, 01:41 PM   #386
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Lost My 65
The patch repairs looks fantastic! There are so many things that can be achieved if a person has welding skills. Looking forward to more updates.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-25-2013, 02:30 PM   #387
Snailed
Snailed's Avatar
Re: Lost My 65
Nice, a piece of spring is good. It can be pretty time consuming but it's so nice to use the old panels and minimal filler.
Good luck with the barn and the sheetmetal!
Old 09-11-2013, 10:53 PM   #388
LostMy65
LostMy65's Avatar
Re: Lost My 65
I have finally settled on a method I'm happy with for repairing the body panels.
Until I retire, (longways down the road) I won't be doing a frame off restore. Also, I don't want too much tore down for too long.
I want to keep it a driving restoration.
Also, i dont like different panels different colors.
Also, I didn't want a primer gray, red or black truck.
I like blue. Captn' suggested blue primer, but I read that primer doesn't protect metal. Later I realized he might have meant epoxy primer.
My truck is parked inside, so fading is no immediate concern.
Now, the next criteria for my attempt to tackle these repairs is equipment - I don't have the spray equipment - and even if i did, I don't feel comfortable spraying toxins (poison) in my garage. Even if I dress up in a full bunny suit, where do I ventilate these toxins? Also, I'll be doing a small repair, then moving onto another small repair. I dont feel like setting up everything for every small repair, and then cleaning everything up.
The solution; roll-on epoxy primer.
In my research, I found that the really fine foam rollers do a nice job.
Now, I do realize that rolled on primer on my truck will still look like primer on a truck, but I like the look of trucks in primer. http://67-72chevytrucks.com/vboard/s...84#post5077484
Also, getting the repair areas to blend with the overall truck would be a challenge. But about a month ago I remembered a look that I really like for a driving restoration.
MisterC's 66:
So, I now I have a method/direction/procedure that I'm happy with. This way as I repair an area it's done correctly for when I decide to do a frame off restore and give it a paint job with quality paint.
I had a local paint store mix up some enamel the same color as the blue epoxy.
The bottom right is the epoxy. - good match:
Here is my first attempt to emulate MisterC's truck:
(I really like how it's turning out.)
Old 09-11-2013, 11:18 PM   #389
MisterC
MisterC's Avatar
Re: Lost My 65
Looks nice! Keep up the great work, bud. I almost feel bad for starting to sand mine now. I needed to get down to the white parts underneath so that I could see if I wanted to go with the two tone.
Old 09-12-2013, 06:20 AM   #390
Low Elco
Re: Lost My 65
You know, that's kinda neat. Almost like built in patina. And well protected. Nice work!
Old 09-12-2013, 09:13 AM   #391
LostMy65
LostMy65's Avatar
Re: Lost My 65
Thanks guys.
Yeah, MjsterC's is blue primer with a black guide coat.
I'm just faking it for now.
Originally Posted by MisterC View Post
This is the way I got it. Blue primer with a "dusting" of black. I don't do body work, but I'm assuming that has a purpose. I'm planning on putting all of the trim back on, as paint will be the last thing I do to it.
Old 09-23-2013, 02:48 PM   #392
LostMy65
LostMy65's Avatar
Re: Lost My 65
Another huge reason for the direction I'm going with the paint and body is when I first decided on getting a classic to tinker on, I settled on a truck for the practicality of it.
I want to be able to use it as a truck.
This last Wednesday was the perfect example.
I went to pick up a big steel gate. It didnt quite fit in the bed.
It caused some pretty good scratches.
No big thing. Just hit it with some sandpaper, and touch it up.
I own a truck.
Here is a post Mark made quite some time back that stuck with me and convinced me of the direction I wanted to take for the body and paint:
Originally Posted by markeb01 View Post
That’s exactly why I used it, I've had more fun with the truck since the blitz black than I ever did when it was wearing shiny paint. I drive it everywhere now. Before I used to worry about the paint getting scratched.
I originally painted the truck in gloss black lacquer (which chips easily) nearly 15 years ago. It was my daily driver for a 72 mile commute for 9 years and we lived on a rock road, so the paint really took a beating. Due to the number of chips, and since I didn’t want to disassemble the truck to strip all the lacquer I just feather edged everything and then surfaced the bad areas with U-Pol primer (applied with a roller). I also removed all the seam sealer on the roof and resealed it with self-leveling Evercoat Maxim.
I bought two gallons of paint (just in case) and used about 5 quarts to paint the exterior. I didn’t paint inside the bed. It was either $30 a gallon or $50 a gallon. I don’t remember for sure and lost my receipts in a computer crash back in August. With all that, some thinner, Rage body filler, and sand paper I probably had another $100-$150 dollars invested when it was all done. So it cost somewhere a little over $200 for the whole job.
Old 09-23-2013, 02:53 PM   #393
T Smith
T Smith's Avatar
Re: Lost My 65
Looks great! Reminds me of the flat denim blue that was all the rage on Harleys a couple years ago.
I do love a blue stepside.....
T Smith is offline   Reply With Quote
Old 09-24-2013, 03:32 PM   #394
LostMy65
LostMy65's Avatar
Re: Lost My 65
Thanks for the compliment.
I hadn't heard of denim blue as a paint color.
I googled it and found these:
(I like it)
Old 09-24-2013, 03:39 PM   #395
T Smith
T Smith's Avatar
Re: Lost My 65
One of my riding buddies has a Fat Bob that's denim blue, looks good but it really shows fingerprints and stuff.
Old 10-27-2013, 04:48 PM   #396
LostMy65
LostMy65's Avatar
Re: Lost My 65
Winter Goal
I've decided to go with an Automatic Tranny.
Driving around this summer in the curvy hilly stop-and-go Portland OR area was the clincher.
I'm tired of shifting up and down and up and down.
So this winter I'll be putting in an Auto.
My 65 is on a 62 Frame,
so this will go a little different than those who have the 63-66 frame.
I'm currently rounding up the parts needed to go from my sm420 to the th350.
I acquired a nice original 3-speed auto column sometime back.
I'm sure glad the offers I got for it were lower than I knew it was worth, otherwise I might not of held on to it.
I'm looking forward to this upgrade.
Here are some pics of the column:
Old 10-27-2013, 09:21 PM   #397
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Lost My 65
I am building a 62. Using a 350/700R4. Modified a Camaro trans x-member to hold the trans.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 10-27-2013, 10:25 PM   #398
A.T. RockDriller
A.T. RockDriller's Avatar
Re: Lost My 65
That did wonders for my vertigo......
How bout some pic's of the '62, Chris...?
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 10-28-2013, 12:07 AM   #399
66-PMD-GMC
66-PMD-GMC's Avatar
Re: Lost My 65
I have the chassis almost done.
Static coil drop. (no more torsion suspension)
Disk front and rear and epoxy coat chassis paint.
It's a ground up build...
Nothing is done on the cab, bed or front clip...
Projects..
440CID 2X4 Pontiac
Old 10-28-2013, 05:39 PM   #400
LostMy65
LostMy65's Avatar
Re: Lost My 65
That is a long tranny dipstick tube.
I'm going to need the same thing beings I need to get past the heater box in the engine compartment.
Do you remember which one you have?
Do you know if the th350 will accept the same one?
