07-13-2013, 09:47 AM | #1 |
69 C20 front end ?
I have a 69 c20 with drum brakes on the front, I want to keep the 8 lugs on it but i want to lower it and put disc on it so what is the best way to do this...
07-13-2013, 10:03 AM | #2 |
Re: 69 C20 front end ?
I believe 71 was first year for disc, too bad because I junked my 71 c20 frame with everything. Not sure on lowering though.
Posted via Mobile Device |
07-13-2013, 04:35 PM | #3 |
Scrapper 1
Go out and buy New drop spindles for a 3/4 ton truck and get all the disk brake parts and poprtioning valve is very important
07-13-2013, 06:13 PM | #4 |
Take a look at this.
http://67-72chevytrucks.com/vboard/s...68&postcount=4 You'll also need a c20 master cilynder from a 71 or 72 and a porportioning valve. If you'd like I can describe my set up with what I have for my 69c20. Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
07-13-2013, 09:05 PM | #5 |
Roto Reuter thats the name...
I did an 8-lug disc brake conversion on my 69 C20 last year. I was not sure what way to go. I was undecided between a CPP kit or Performance Online (POL). I decided to go with the POL kit. CPP makes a good product, but I heard many negative comments on this forum about their customer service. I was very pleased with the POL kit.
Or you could find an 8 lug square body truck and swap out the complete front suspension/brakes/engine crossmember. Not many bolts to remove the crossmember from the frame. You roll out the drum setup and then roll in the disc setup. You now have disc brakes and the higher quality ball joints. I figured if I did that I would have to replace some stuff on it anyway so I went with the new kit. Sorry I don't have pictures of it completed. I should take some.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
07-14-2013, 10:41 AM | #6 |
So is 71-72 8 lug trucks are the only parts i can use if i dont change the front cross member out for spindles.I have only had the truck now for 3 weeks and very new to these trucks...
07-14-2013, 11:35 AM | #7 |
The guy that owned my truck before me swapped it out to disks from a mid 80s c20 but kept the old a arms. I'm assuming he switched ball joint and spindles from the newer truck but I'm not sure.
