Old 07-13-2013, 10:08 PM   #1
texastrendz
Fuel line routing?
Would like to see how you guys routed fuel lines from the motor down to the frame. I want to keep everything tied to the frame and not the body if possible. But any and all photos would help, Thanks Daniel
texastrendz is offline   Reply With Quote
Old 07-14-2013, 12:41 AM   #2
Kim57
Kim57's Avatar
Re: Fuel line routing?
Here's what I did.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-14-2013, 01:08 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
pretty much how mines run...I used all s.s. flex hose tho. Runs down the back of the motor and across the trans to the frame rail, and hugs the frame rail all the way back to Vette reg/filter, pump, prefilter and tank.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-14-2013, 07:44 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I brought mine up and over, and met it with hard line run up from the frame. It doesn't anchor to the body.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-14-2013, 10:08 PM   #5
texastrendz
My truck is equipped with a Porterbuilt Dropmember. The motor is raised up a bit and my manifolds are angled high and sit pretty high on the frame rail. Wonder if anyone with a dropmember has picks. Gonna set the cab back on this week, will see what kinda room I got.
Old 07-15-2013, 04:54 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
http://67-72chevytrucks.com/vboard/s...&postcount=536
Another LINk
Old 07-15-2013, 05:15 PM   #7
mooseknuckles
mooseknuckles's Avatar
Originally Posted by Kim57 View Post
Here's what I did.
Kim
same here too...mine run to the outside of the frame to the reg/filter under the pass seat area.....
mooseknuckles is offline   Reply With Quote
Old 07-16-2013, 10:26 AM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-20-2013, 12:11 PM   #9
BigRed76
BigRed76's Avatar
Not trying to hijack the thread, but does anyone have the part numbers for the fittings used to make the lines you guys used off of the fuel rails?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-20-2013, 04:40 PM   #10
mooseknuckles
hope this helps.....
Old 07-20-2013, 05:18 PM   #11
BigRed76
BigRed76's Avatar
That is exactly what I need. Thank you.
Zach
Old 07-20-2013, 05:59 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have an extra set of the Russel EFI push connect fittings; but keep in mind that many have the OLD design, which uses a regular plastic center clip. These CAN and HAVE come off before under rail pressure. I had a return line fitting come off and pump fuel onto hot headers.
YOU NEED TO USE 644110 or 644120, these are the NEW design parts for 3/8 and 5/16 push on fuel fitting to -6 AN. Some have used the old style for a long time, but there has been more than 1 car lost to a fire caused by the fittings.
http://www.summitracing.com/parts/rus-644120/overview/
http://www.summitracing.com/parts/rus-644110/overview/
If you want the old style, you can have my set for the cost of shipping....but frankly thats at your own risk.
Old 07-20-2013, 09:29 PM   #13
Kim57
Kim57's Avatar
Those are what I used
Pretty cheap insurance for a safe connection.
Kim
My build thread
Old 07-20-2013, 09:38 PM   #14
SeTx67
SeTx67's Avatar
Lot of great info in this thread. Thanks
SeTx67 is offline   Reply With Quote
Old 07-20-2013, 10:55 PM   #15
68GMCCustom
I need to update to those....tho I do have the fittings tension relieved/tie wrapped down in the hopes that it won't move until I do change it.
Kurt -
Old 07-20-2013, 10:59 PM   #16
BigRed76
BigRed76's Avatar
Glad you said something about that because I would've gone and ordered the old style...
Zach
Old 07-21-2013, 11:21 AM   #17
Hart_Rod
Hart_Rod's Avatar
Good info guys!
Hart_Rod is offline   Reply With Quote
