dazed and confused
going from power to manual brakes
What is involved with changing from power drum to manual drum brakes. Do you just take the booster off and bolt the mc to the firewall? Thanks
members met: redbaron69, billsbowtie,nc67 |
![]() Join Date: May 2012
Re: going from power to manual brakes
why would you want to do that? i have to ask.
dazed and confused
I have a truck with manual brakes. They work great. The power brakes have been trouble. I like the manual better myself. Just personal preference I guess
2WD Jimmy
![]() Join Date: Mar 2005
Does that other (manual) truck have disks? Manual drums are like an old Farmall tractor... not so great. I would fix the issues with those power brakes iiwm.
That line brings back some childhood memories. Hundreds of hours raking hay on the old Farmall M.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
I suppose you would need manual MC w/ the proper length push rod and some new brake lines to MC. My Oreillys had a good selection of fittings (weren't listed online).
FWIW manual front disc is my favorite combo for maintainability/performance. |
I did brake job (manual drum) on 66 GMC a few years ago.
New WC, MC, front drums, flex, shoes. Worst brakes ever. I cleaned them the other day and noticed the low mileage front shoes had cracks. Cleaning didn't help; feels like shoes are oiled. Need to change shoes again. Just a FYI to note not all shoes are quality. |
#8 | |
![]() Join Date: Mar 2000
Paul @ GMCPauls Last edited by GMCPaul; 07-18-2013 at 12:18 PM. |
^^^^x2
1969 Chevy c20(Miss Hackjob) |
Don't forget pedal ratio changes. You need a hole 1 1/2 inches higher to bolt your push rod to.
#11 | |
Scrapper 1
Not sure why you want to try and put any one of are old trucks in harms way Me i be putting 4 wheel disc brakes with hydro boost or a booster But its your life and your truck I drove a 1965 3/4 ton truck with drum brakes here in calif after i got Power brakes I thank my lucky star's I have help with the booster |
#12 | |
Paul @ GMCPauls |
I have a manual brake rod from my 70 C/10 laying around if you need it.
#14 | |
OP have to tried trading setups with something who may want to go power? Might be easier for all the little parts you need. |
#15 | |
Posted via Mobile Device |
