Old 07-14-2013, 02:21 PM   #1
harvey85
Manifold vacuum
So I am a nub when it come's to vacuum advance and all that crazy stuff. Stock 305 with a quadrajet and EGR valve is capped. My question is which one of these three vacuum sources is manifold vacuum. Is it the vacuum tree behind the carb, the little tee coming off the carb or the single line on the bottom of the carb?Name:  037.jpg
I have read that I should run manifold vacuum because the egr system is disabled.
harvey85 is offline   Reply With Quote
Old 07-14-2013, 02:56 PM   #2
Katrina/10
Katrina/10's Avatar
Re: Manifold vacuum
The one on the bottom and the one behind the carb are manifold vacuum. Not really the right place to connect a distributor. Where was is hooked up originally?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-14-2013, 02:58 PM   #3
tcount
Re: Manifold vacuum
the tree behind the carb or any vacuum proton the bottom of the carb
tcount is offline   Reply With Quote
Old 07-14-2013, 02:58 PM   #4
harvey85
Re: Manifold vacuum
it wasn't hooked up at all. Every vacuum line on the carb was disconnected.
Old 07-14-2013, 07:40 PM   #5
LONGHAIR
Re: Manifold vacuum
There should be a vacuum diagram sticker on the radiator support. It is really not advisable to "partially" disable things. While "stock" is not the greatest, it is better than causing problems from messing with things that have to work together. So...
Put it all back like it was originally, or get rid of it all. That would mean the electronic carburetor, distributor, etc.
It would be better in the long run, but there is some work and cost involved.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
