Old 11-30-2003, 08:25 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
Question turn signal switch
lost brake lights and one rear signal and discovered that you can wiggle the turn signal lever and they work
how hard is it to replace the signal switch thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-30-2003, 08:30 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
It is really easy....pull off the steering wheel, and take out the switch....i did it about a year ago....think it took less than a hour. I don't rember how to explain it...but it is really straight foward, even for a clutz like me
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-30-2003, 08:36 PM   #3
Olden Days
Living In The Past
Olden Days's Avatar
had something very simular happening with my friends 70. we pulled it down to where the switch is exposed then hosed it down with electrical contact cleaner and it started working again. If you do pull it out it is very straight forward. The only area that might be a problem is maybe fitting the wire plug through the rubber gromet without cutting or breaking it. On the one I did the PO had already cut that grommet so I dont know how hard it is to get it through
Olden Days is offline   Reply With Quote
Old 11-30-2003, 09:05 PM   #4
greasemonkey
greasemonkey's Avatar
It's pretty easy to do. If you disconnect the wires from the connector before you thread it through the grommet, you'll be alright.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 11-30-2003, 09:07 PM   #5
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
I just got done replacing a switch in my 71. The first question i ask though is do you have tilt or no tilt. The tilt will determine how easy it is or not. Now granted i put a tilt steering column out of an 81 van in mine but i would reckon it's the same. Just get you a steering wheel puller (you can rent them from autozone) and take off the steering wheel. The turn signal switch itself has 3 screws in it. NOw on my tilt i was able to wrestle it out from there but going back in was another story. theres an outer bracket that has the holes in it for your turn signal indicator and in my case the tilt lever and also the 4 way indicator switch. You can use a 2 jaw puller to take that off if you have that bracket. The bad thing i ran into was putting the new one back in. I had a small area to fit the connector plug through and it just wasn't happening. I had to cut the wires feed em through and then put em back together. after that it wasn't so bad. It's not really all that hard but look forward to a few small minor speedbumps in the road. Good luck
WRMZ71 is offline   Reply With Quote
Old 11-30-2003, 09:30 PM   #6
rage'nrat638
rage'nrat638's Avatar
PICTURE'S WORTH A 1000 WORDS
rage'nrat638 is offline   Reply With Quote
Old 11-30-2003, 09:34 PM   #7
lukecp
lukecp's Avatar
The LMC catalog comes through again!
Curse their high prices, but love those exploded diagrams!
Old 11-30-2003, 09:55 PM   #8
72shadetree
KEEP ON TRUCKING
thanks its a non tilt shouldnt be to bad the worst part is i just swapped out wheels today lol
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 12-01-2003, 02:29 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
At least you know it'll come off easily.
Old 12-01-2003, 03:47 AM   #10
72shadetree
KEEP ON TRUCKING
thats true i gotta go to the dr in the am so betterhalf is going to pull wheel and get started on it maybe it will be finished when i get back lol doubt i could get that lucky
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 12-01-2003, 04:23 AM   #11
A.P.
Black 72 Chevy
A.P.'s Avatar
Easy.
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 12-01-2003, 09:29 AM   #12
70c10
67-72 Addict!
70c10's Avatar
Disconnect battery , you also have to push in hazard button to get the switch out. Take your time.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
