Old 07-15-2013, 05:30 PM   #11
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by Bennett68C10 View Post
Nice job on the fender, I just pulled mine off the front clip and took the trim, markers and emblems off of them. Just wanted to see what I have to work with. I have a little rust work to do and will probably need to blast them. They have surface rust in some hard to reach areas.
Inside the fender at the top is where the worst of mine was at, wish I could have sent them off for blasting and normally would have but the same guys who blasted my cab ($300) wanted $100 each to do the fenders. Crazy. So I had to do it here at home with a 3m paint/rust stripper wheel, screw driver and sand paper and patience! What I couldn't get to with those things I used a wire brush to loosen anything up and used the Fast Etch which converts the rust, then painted those areas with rust encapsulator... took some time but I believe they'll be good for years to come.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
1969, black, custom 10, fleetside, shortbed
