Old 07-16-2013, 12:25 AM   #11
ryanroo
ryanroo's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by 6BT 56 View Post
Hi Ryan truck is lookin super! Put some miles on the thing now ! Do you know how or where to measure the caster camber angle on a dana 60 ? Or what it should be ? Is caster camber even the rite term ? Im looking to increase the of angle of the steering axis of the steering kuckle . That make sence ? Move the lower king pin forward . My truck is kida jittery on the road and you are always paying attention when driving it or else ! Toe is at 0 and it has a new stabiliser . Still a 2 hander tho .
Caster and camber are two different alignment angles. camber is predetermined at the factory and is not adjustable.
caster is the angle of an imaginary line drawn through the center of the knuckle steering pivots compared to a line 90* from perfect level as viewed from the side. kingpin 60s seem to like 3-6* of positive caster(leaned towards the back of the vehicle at the top) so the line drawn through the steering pivots when looking at the drivers side is like this /
if it is wandering it probably needs a little more positive caster. and a smidge of toe in. measure the caster with the truck sitting as level as possible and loaded as it would be normally. then measure the angle of the top of the steering knuckle flat where the steering arm or spring cap is. you can usually get a close enough reading off the bolt heads for the spring cap, but using the top of the studs on the arm is sketch because they may not be threaded in the same amount.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
