lug nuts question
So I have a 1985 chevy k10 and online it says for lug nut 7/16. Some ebay items say 7/16-20 and others just 7/16. Is there a difference between the two?
Posted via Mobile Device |
Re: lug nuts question
1985 half ton.............. 1/2 -20
![]() Join Date: Jul 2010
tha -20 stands for tha thread count or pitch..i forget which one
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
![]() Join Date: Sep 2009
This. I just bought 20 new ones last week.
Experience is something you gain when you didn't get what you wanted in the first place. No great defeat was ever just possible in the beginning. |
4wd has 7/16
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
item.mobileweb.ebay.com/viewitem?index=0&sbk=1&nav=SEARCH&itemId=260910760167
Thats what I ordered will they work? Posted via Mobile Device |
Are your wheels steel or aluminum?
Aluminum. I got the rockstar xds
As long as you got the lugs for aluminum wheels, they should work fine.
The description did not say that it was for either type of wheel
Some of them are a little different, but you should be ok.
Just to re-iterate what was already mentioned:
1/2 ton 2wd = 1/2" lugs quantity of 5 per wheel 1/2 ton 4wd = 7/16" lugs quantity of 6 per wheel K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#13 | ||
Thread count, with American sizes, is expressed as "threads per inch" (TPI) Pitch is the distance between threads (single start). So a bolt with 8 TPI would have threads 1/8 of an inch apart. ETA, the ones who just list the size as 7/16 assume the you know that automotive lug studs and nuts are always fine threaded. This is done for 2 reasons. First, the minor diameter (bottom of the threads) in larger because the threads are not cut as deep. This makes them stronger, with all else being equal. Second, you get more clamping force for the same amount of torque applied to the nut. Multiple start threads are completely different....and not in automotive use. They allow for more travel with fewer revolutions, at the cost of less clamping force. They are usually found on larger diameter pieces. It gives the strength of many threads but screws on quickly. More than you ever wanted to know......lol
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 07-18-2013 at 09:54 AM. |
