Old 07-18-2013, 03:23 PM   #1
RocketKing
RocketKing's Avatar
Brake question
When I finished my truck I noticed the brakes were stiff and even if I pushed to the floor it would not complete stop, so I screwed in the brake booster rod and the pedal felt great and the brakes worked...
until I noticed how incredibly hot the front wheels were getting, turns out the booster rod was adjusted to far in and was not allowing the piston from the master cylinder to come far enough back to completely release the front disc brakes. Bad for pads not to mention gas mileage. lol
Now if I adjust the booster rod far enough that the disc will disengage after I take my foot off the pedal, it leaves a stiff pedal that will not stop well and not much emergency stop at all. But if I adjust the rod enough to get good pedal then the brakes will not disengage.
Where do you suggest I start? My first guess would be to bleed the brake lines again (been done twice) this time using a pump or vacuum and go from there, in case I missed some stubborn air bubbles.
Any other suggestions or anyone else every had this problem?
Rex
RocketKing is offline   Reply With Quote
Old 07-18-2013, 03:34 PM   #2
mmiddle
mmiddle's Avatar
Re: Brake question
It's been a while.... about 10 years. BUT if I remember right the internal push rod from the Booster to MC is adjustable too. This my be your problem.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 07-18-2013, 03:37 PM   #3
Wrenchbender Ret
Re: Brake question
Make sure the rear brakes are adjusted up good.
Wrenchbender Ret is offline   Reply With Quote
Old 07-18-2013, 05:03 PM   #4
RocketKing
RocketKing's Avatar
Re: Brake question
Hmmm... internal push rod, that may be the answer. I am glad you can remember things from ten years ago... I have trouble with 10 minutes ago! lol
I actually have tried that, I may have to double check it. Thanks!
Rex
Old 07-18-2013, 05:17 PM   #5
Rufton
Re: Brake question
I did 66 C1000 brake job in 2006. New front drums, all new wc,new mc, front flex and all new shoes. Those are the worst drum brake shoes I've ever experienced; and I've installed my share. Bad from day 1. Hard pedal but I don't think truck would skid on wet road. I noticed the shoes have hair line cracks when I cleaned them a while back. Cleaning helped zero.
I have some Raybestos 228PG in the mail. I'm hoping they will work.
Rufton is offline   Reply With Quote
Old 07-29-2013, 07:35 PM   #6
Rufton
Re: Brake question
FWIW. The ordered Raybestos were out of stock. No time, so I bought front shoes from OReilly's. During bleed I discovered that rear flex line was completely plugged which means no rear brakes. Installed new rear flex and Oreilly front shoes and brakes work good now. Not sure why old front shoes were cracked.
