Old 07-18-2013, 09:23 AM   #1
eagleuh1
eagleuh1's Avatar
Ball joint press?
Anybody with a 3/4 ton C20 found a portable ball joint press that fits and works. I've tried Autozone and O'Reillys and neither has a big enough throat to fit over the lower ball joint. This is on a 68 C20. If not, guess i'll be pulling lower CA's and going to a shop to have pressed out and new 85's pressed in for disc break conversion. Thanks. Jim
eagleuh1 is offline   Reply With Quote
Old 07-18-2013, 09:39 AM   #2
Fldawg
Fldawg's Avatar
Re: Ball joint press?
snap on or otc
Fldawg is offline   Reply With Quote
Old 07-18-2013, 10:19 AM   #3
eagleuh1
eagleuh1's Avatar
Whats OTC? And thanks. Jim
Old 07-18-2013, 10:34 AM   #4
Lattimer
Lattimer's Avatar
Thats a brand name that makes tools like this.
Having done these ball joints on a 1/2 ton, I'd take them somewhere in the future and just have them pressed in and out. Even with the ball joint press mine were kinda miserable.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-18-2013, 11:12 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I have the OTC press with all the accessories and I haven't found any I can't do. but I have made some of my own sleeves to do things it wasn't designed for. My suggestion is take a piece of pipe and some plate and make the sleeve you need
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-18-2013, 02:12 PM   #6
eagleuh1
eagleuh1's Avatar
The sleeves not the problem. The C-frame for the press isn't wide enough to fit over the ball joint. The kit has the right size sleeves. I'll probably weld up a box tube press tonight or tommorow and just use the bolt and sleeves from the kit. Thanks for the replies. Jim
Old 07-18-2013, 02:17 PM   #7
Ol Blue K20
I see the problem, mine opens to almost 12"
Dale
Old 07-18-2013, 02:52 PM   #8
JointTech
JointTech's Avatar
i just did the suspension on my C20. I didnt need any thing special for the lower balljoints. I used the autozone rental balljoint press.
God help you getting the uppers out though.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-18-2013, 03:22 PM   #9
k2rm
k2rm's Avatar
I used the harbor freight set to remove the original ball joints on my C20 a couple years ago.
http://www.harborfreight.com/ball-jo...cles-4065.html
No issues, worked great...
k2rm is offline   Reply With Quote
Old 07-18-2013, 06:35 PM   #10
volksworld
the one I have looks like that harbor freight one pictured above...its an ATD 8699...the throat of the "c" is 6 inches....it did the lowers on my 92 one ton P-30 motorhome...cant imagine the C-20 being larger
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-18-2013, 06:36 PM   #11
1stchevy
1stchevy's Avatar
I have the harbor freight and have had no complaints with it, I'm sure if I were a mechanic I would want something higher end.
1stchevy is offline   Reply With Quote
Old 07-18-2013, 06:45 PM   #12
Longhorn 70
Longhorn 70's Avatar
I used the AutoZone press to do mine. I did have to use an air hammer to press the old ball joint out. The new ones went in very smoothly.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
