Dude...I'm a CHICK
Rust bubbles,
Just about feel like crying (haven't ruled it out) My truck has been painted for about 3 years, (keep in mind that it has been kept sheltered from weather too) after less than a year, I noticed a few bubbles over the drivers side tail light. I called the body shop, they basically said, sorry, we cant guarantee the paint job because we cant see rust between the inner and outer body panels. It could have been forming there all along. Fine, suck it up. Well I took my burb out today and noticed that most of the passenger rear quarter panel between the marker light and the wheel well has hundreds of tiny bubbles coming up under the paint. This coupled with all the other short cuts and major screw-ups by the body shop that I had tried my hardest to just "suck up". My heart has sunk.
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
Re: Rust bubbles,
I'll be optimistic, maybe it's not rust. Could be a reaction of the top coat to undercoat or material used in the repair process. Only one way to find out.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: Rust bubbles,
since you are a girl you can go ahead and cry. but not for long. theres no crying in trucks!!!
sucks but I guess old stuff rusts. I always wondered about these high dollar restos. You can put all the paint and primer you want on a body panel but you cant get inside the panels. Ive seen these long tube things they use to try to spray the inside of doors and other areas you cant really see but how good could that work? I guess the only way to stop it completely is a complete frame off with new panels. |
Roadtrip!
![]() Join Date: Feb 2003
Re: Rust bubbles,
If there are hundreds of bubbles like you say, i would tend to believe this. ^^ In which case they should fix it, but after 3 years... Tough call. I feel for ya.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
CAN'T FIX NOTHIN
this is why I do my own paint and bodywork , stripped and painted my 67 Camaro in 02 took two GM left front fenders cut them in half and put them on my car in 02 painted it and not a bubble since so far , stripped my 67 c10 and painted it in 07 did have a couple bubbles in the paint this year around my back window but that's it , I don't trust body shops at all , on a good note if it looks like you describe its probly not rust ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Rust bubbles,
I agree probably not rust but the paints popping
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: Rust bubbles,
Maybe solvent pop ?
84 step side 87 swb |
Dude...I'm a CHICK
Re: Rust bubbles,
Thanks yall, I had my cry....yeah, I did.... now, if its not rust, what's the worst thing that will happen with these bubbles? It just makes me sick. I wish I could do stuff like that myself.
junk
Re: Rust bubbles,
I'd take it to the painter and have him evaluate it. Get an estimate for a reshoot and blend. Get a second opinion and estimate. If it is some chemical reaction I would not be in a hurry to get it fixed. Let what ever it is run it's course. The body shop of your choice will be able to guide you to your best course of action.
![]() Join Date: Apr 2013
Re: Rust bubbles,
Your a girl its ok to cry... Hell I cry sometimes for stupid sh*t. Keep your head up, hope for the best. Everything can get fixed...
Eric (Evaded)
If I see a Zombie.. Im runnin it over with my Truck. |
Re: Rust bubbles,
You should see our truck. It has huge bubbles under the paint on the roof. I'm told its rust but idk for sure. Ill drive it till it has to be fixed and do it then.
1969 Chevy c20(Miss Hackjob) |
Re: Rust bubbles,
Heck Jodie,when I saw the title with your name it made "me" cry
![]() One thing I've found,you take a truck from the dry West that is rust free back East to where there's moisture in the air and it doesn't take long to see rust. There's rust even in the Southwest,but it's very inactive,slow growing,non-aggressive. There is light rust on the bare metal behind all panels after 40 years. You bring that back East and next thing you know holes start showing in the rockers,even if you never drive in winter.
![]() ![]() Join Date: Jan 2011
Re: Rust bubbles,
^^ .. yeah, post up a picture and we'll see what's up. Doesn't sound like rust to me either. It could be the truck wasn't sealed with Epoxy (or similar) under the primer which allowed moisture to penetrate and the paint is literally rusting from the inside out. Was it stripped to bare metal when you had it re-painted?
Re: Rust bubbles,
a few pictures of these "bubbles" would help us to give a better diagnosis of what you're dealing with here junk. If there are this many bubble, I doubt that it's rust at all. Rust will usually occur as 1 or 2 bigger bulges in your paint. This sounds a lot like solvent pop to me but 3 years after the fact also seems unlikely. Unless the clear was sprayed to soon after the base color was laid down and the truck, a couple years later, sat in direct sunlight for hours on end. That could cause some solvent pop and de-lamination of the clear coat.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#15 |
Dude...I'm a CHICK
Re: Rust bubbles,
Thanks for your replies yall. K, I had horrible rust before I moved from Cali, I just waited til it was near falling apart before I could afford to paint it. Yes it was taken down to bare metal, and all my rusty pieces were cut out and replaced. It has never sat in the direct sunlight for any period of time, and the bubbles "look" like they are under the color not just the clear coat. I will never take my truck back to the people who painted it.
#16 |
Cruzin
Re: Rust bubbles,
I hate this for you after all you been though. Just remember paint won't get ya home
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#17 |
Dude...I'm a CHICK
Re: Rust bubbles,
lol, thanks Hubs, I know that, and it has been running pretty good, its just so gosh darn frustrating.
#18 |
Re: Rust bubbles,
Sorry to hear of your troubles,
#19 |
Re: Rust bubbles,
Everyone hates to redo anything,especially paint & body work. I bet it still looks great when you stand back. So,it's not so great for shows,but mostly you spent hard earned cash and expected it to last way longer than this. It would sure gnaw at me. I never see Suburbans that have never rusted in the bottom/lower side. I see them in CA just like anywhere else with rust. The local funeral home has the '68 Panel they bought new as the first vehicle. It's always been stored inside and kept sparkling clean. But,it has bubbles in the rear lower quarter. I'm sure it was run in the winter back before it's retirement...people die year 'round. It looks great and I'd love to buy it. If I fixed the rust I'd do everything imaginable to prevent it's come-back. Other than avoiding rain like the plague and storing inside,I think I'd cut the inner wall to treat and seal the backside of the body,then repair the inner wall...or fab up an access panel. I also believe in putting drain holes where the General didn't and bigger ones where he did.
