Old 07-18-2013, 12:44 PM   #1
62k10&84k20burb
62k10&84k20burb's Avatar
Question how many 62 k10's produced?
Does anyone know how many 62 k10s with a 235 and a 4spd where produced?
62k10&84k20burb is offline   Reply With Quote
Old 07-19-2013, 01:00 PM   #2
61K10
61K10's Avatar
Re: how many 62 k10's produced?
I have a 61k10 and have never found any info on production # on how many were built. probably not too many.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-19-2013, 01:28 PM   #3
1963c-10
1963c-10's Avatar
I have production number sheets on 60-66 truck models....I just have to find them. It only broke them down by various model and wheel base #'s.
1964 Short bed trailer
Old 07-20-2013, 04:30 AM   #4
spacedebris
actual production numbers for chevy/gmc were not kept prior to '63. If you have a '63 or later, those numbers are readily available but '62 and earlier no date was kept so the best you can hope for is a rough guess but nothing you can hang your hat on.
spacedebris is offline   Reply With Quote
Old 07-20-2013, 10:50 AM   #5
bhc41051
bhc41051's Avatar
Here are production numbers for 1966. You should be able to ballpark for your truck. I wouldn't think there would be a huge swing one way or another from year to year. http://www.oldride.com/library/1966_chevrolet_c20.html
bhc41051 is offline   Reply With Quote
Old 07-20-2013, 03:26 PM   #6
spacedebris
Here are some numbers I found. I may have been mistaken when I said they were available after 1963. The numbers are not available prior to 1965.
1965 4x4
K-10 (1/2 ton) Max GVW 5600 lbs WB 115"
Stepside 1,127
Fleetside 633
K-15 (1/2 ton) Max GVW 5600 lbs WB 127"
Stepside 513
Fleetside 1,459
total 1965 1/2 ton 4x4 = 3732
1966 4x4
Stepside 457
Fleetside 1,976
Stepside 1,123
Fleetside 678
total 1966 1/2 ton 4x4 = 4234
1965 4x2
C-10 (1/2 ton) Max GVW 5000 lbs WB 115"
Stepside 52,899
Fleetside 55,300
C-15 (1/2 ton) Max GVW 5000 lbs WB 127"
Stepside 2,743
Fleetside 15,774
total 1965 1/2 ton 4x2 = 126,716
1966 4x2
Stepside 59,947
Fleetside 57,386
Stepside 26,456
Fleetside 17,875
total 1966 1/2 ton 4x2 = 161,664
Old 07-20-2013, 07:31 PM   #7
1963c-10
1963c-10's Avatar
1963 chevy truck production numbers:
Pickups with 6.5 foot boxes, Step-Side, Fleetside, Panel and Suburban models where available in 2 wheel or 4 wheel drive. These new models came with a new coil-spring front suspension along with the introduction of a few new 6 cylinder engines; the 230 and 292 series. Also new for 1963 was the introduction of the alternator. Calendar year production on the 1963 models totaled 483,119. An astonishing 1/3 of every truck produced during this year was a Chevrolet.
A 1963 Chevrolet Pickup can be distinguished by the grille which had a more egg-crate appearance and headlamp bezels and Chevrolet lettering was accented in black. Parking light lenses where the same as previous years, except federal regulations now required the automotive industry to change from clear to amber.
Old 07-20-2013, 07:33 PM   #8
1963c-10
1963c-10's Avatar
This page list production info & numbers on many different chevys from the 40's forward
http://www.oldride.com/library/chevrolet.html
Old 07-20-2013, 07:58 PM   #9
padresag
Pickups with 6.5 foot boxes, Step-Side, Fleetside, Panel and Suburban models where available in 2 wheel or 4 wheel drive. These new models came with a new coil-spring front suspension along with the introduction of a few new 6 cylinder engines; the 230, 250 and 292 series. Also new for 1963 was the introduction of the alternator. Calendar year production on the 1963 models totaled 483,119. An astonishing 1/3 of every truck produced during this year was a Chevrolet.
the 250 eng was not introduced until 1966
ron
padresag is offline   Reply With Quote
