07-18-2013, 10:33 PM | #1 |
Junk Yartist
Are these 60-66 wheels?
Just wondering... They have tabs for the hubcaps, and they were on my 66 when I bought it.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
07-18-2013, 11:03 PM | #2 |
1961 crewcab
Re: Are these 60-66 wheels?
I just got some very similar to that , but wider/deeper offset, they turned out to be for a dodge camper special
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-19-2013, 08:33 AM | #3 |
That's the same rim that came factory on my 66 K20. You mainly see these 67 on up but I have a pair paint matched on a blue 60 3/4 to Camper truck out back. Good chance the rim will be dated either by the valve stem area or between the beads . Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
07-19-2013, 08:35 AM | #4 |
One more thing, since you have a 1966 what does the SPID sheet say, they might be on there ?
07-19-2013, 12:13 PM | #5 |
Junk Yartist
completely forgot about the SPID. I didnt ever bother to look at it since I had these on the back and split rims on the front when I got it. I forgot how much I love your truck.
07-20-2013, 11:58 AM | #6 |
It appears your truck was special ordered with 16.5" wheels. In other words, these rims were not a standard option in 1966. They were offered as a standard option in 1967. If you notice, your spid does not have a typical option code when it lists the wheels, no letter in front of the numbers. All other options on your spid have letters in front of the numbers. I believe the aftermarket introduced the 16.5" wide base camper wheel around 1963.
07-20-2013, 12:06 PM | #7 |
Correct, its a Central Office Production Option. Still have not been able to find that option number in the books.
