![]() Join Date: Jan 2012
tach conversion
does any one know if this tach could be converted to operate without transmitter, removed from ac 60 but failed to get transmitter.It seem's like i read that somewhere at one time
Re: tach conversion
1966 ,
Yes Williamson converts the tachs to run without transmitters. I have the '60 305 V-6and have upgraded to Petronix, I too was wondering if I needed a transmitter. I called and email them and they explained that they do the conversion inside of the tach. http://www.williamsons.com/Tachometers.php
http://s1299.photobucket.com/user/jb...23904108567829 |
Re: tach conversion
ok, thank,s for the info i will check on that .
Re: tach conversion
Installed the same one in my 65 since the old Stewart Warner outside the original cluster went south. Works great.
Re: tach conversion
a lot of people on this forum said this was not a factory tach, i personally pulled from a c60 truck and all mounting plate's in cluster look factory, but like i said before did not get transmitter and cannot find one as of present time unless this website you give me has one ,but i will get tach converted just be a lot simpler may not be exactly in appearance as the other factory tach's that most guy's have but i like the look's of it {dare to be different} I appreciate all the help and comment's ,thank's
Re: tach conversion
I got mine from one of the truck catalogs. Hooked it into the "tach" port on my HEI distributor cap, a hot ignition wire as I recall and works great. I'm not into complete stock issue since mine is a complete 4x4 mutt, but I like the simple look.
![]() Last edited by OldTrucksRule; 07-20-2013 at 01:03 PM. Reason: add image |
