Old 07-20-2013, 10:35 PM   #1
DieselRat
Re: 54 GMC, S10 swap, OM617 diesel
Got the pan ground down enough for the starter to clear fine. Actually went a little further than I needed to. Hopefully get the trans and engine all mated up tomorrow and maybe pull the cab back off.
DieselRat is offline   Reply With Quote
Old 07-21-2013, 09:42 PM   #2
DieselRat
Pulled my lower pan off today, where I cut and welded it was leaking in one spot, so I welded thst up and resealed. Took some pics that may be beneficial to anyone doing an OM617 swap in the future.
Here you can see where I modified it to not interfere with tie rod ends.
Here is the oil pickup, I searched everywhere to find a pic like this showing location so I knew where I could/couldnt plan to cut the pan before I took it off.
View from front.
Adapter and flywheel bolted to the engine. No issues there at all, everything lines up nicely.
Clutch bolted up. Went with a napa labeled LUK clutch, which is oem for jeep and a good set for my truck.
And lastly I stripped it back down to the frame so I can mount the engine and make a crossmember without working around the cab.
Old 07-21-2013, 10:44 PM   #3
1994Sierra350
This is looking awesome. I have to say, a Mercedes turbo-diesel swap is pretty unique. Looks like your making quick progress. Keep it up.
1994Sierra350 is offline   Reply With Quote
