Old 07-20-2013, 08:50 AM   #1
1985GMC
Correct breather set up for differential
My front and rear diff have rubber breather lines coming off them but unfortunately they are open. What is the correct set up for those breather hoses. I don't like that they are open, they let moisture and debris in.
1985GMC is offline   Reply With Quote
Old 07-20-2013, 09:20 AM   #2
79Betty
79Betty's Avatar
Re: Correct breather set up for differential
The have the type of clamp u can get off woth channel locks and a breather end/cap. I've seen it somewhere they got breather bolts that go in the diff bolt where u check/add fluid at. Made of cork. If you're going for a driver/shower it's pretty clean
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-20-2013, 09:51 AM   #3
dieseldawg142
dieseldawg142's Avatar
on my K30 i routed the front axle breather up beside the battery, & the rear up as hi as i could get it on the box. they had the plastic, always sticking breathers, found some nice billet ones on line for just a couple bucks.
if your really manly, you could do like my bud did, he slipped baby bottle nipples over his. works good, keeps the crap out & lets them vent, but you are driving around with nipples on your truck...
dieseldawg142 is offline   Reply With Quote
Old 07-20-2013, 08:08 PM   #4
1985GMC
Hahah nipples. That reminds me of the a lame non turbo cummins that did the ricer fly by past me. So I can just get any random breather and put it on? I wasn't sure if there was a lot of vacumn or something and I would disturb it.
Old 07-20-2013, 10:35 PM   #5
Blackpony
Blackpony's Avatar
Naa any sort of breather that keeps debris out will be fine. The is very very very minimal if any air that will need to escape.
Blackpony is offline   Reply With Quote
Old 07-20-2013, 10:40 PM   #6
INSIDIOUS '86
INSIDIOUS '86's Avatar
As the air and fluid heats inside it expands. A breather just allows that to come out rather than blowing oil out your seals. Just route a longer hose like said above
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-21-2013, 08:42 AM   #7
Keith Seymore
Keith Seymore's Avatar
From the factory it had a small plastic fitting with a loose cap on the end.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-21-2013, 02:02 PM   #8
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
K
You can get these from Classic Parts for like $1.95. I got one for the differential and gas vent earlier this year.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
