Old 07-20-2013, 10:30 PM   #1
DREW67
DREW67's Avatar
67 Hood Installation HELP!!!
Need help with HOOD installation. My hood sits up at the cowl and then at the grill it does not fit well. I will post pictures shortly.
Is there a good method.
DREW67
DREW67 is online now   Reply With Quote
Old 07-20-2013, 11:58 PM   #2
Mister-B
Re: 67 Hood Installation HELP!!!
You just need to loosen the bolts on the hinges here and there, push or pull it where you went it, ratchet it down, close the hood to see how close you are then rinse and repeat. If the hood is sitting up like that at the cowl, it would effect how the front fits.
Mister-B is offline   Reply With Quote
Old 07-21-2013, 12:06 AM   #3
Daner
Daner's Avatar
If I remember I take a permanent marker and trace along the outside of the hinges before I remove or loosen anything. It makes things easier when reassembling.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 07-21-2013, 09:31 AM   #4
cdowns
cdowns's Avatar
worn out hood hinges with alot of slop allows hood to pop up at the cowl many times// that cant b adjusted out
Old 07-21-2013, 09:48 AM   #5
67swb72klb
67swb72klb's Avatar
^ x2 check the rivets on the hinges
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-21-2013, 10:03 AM   #6
Tinkermc
Aligning body parts is not an exact science but most will agree it can be a PITA
Tinkermc is offline   Reply With Quote
Old 07-21-2013, 09:30 PM   #7
DREW67
DREW67's Avatar
Thanks all I will try it out.
DREW67
Old 07-21-2013, 09:39 PM   #8
Codez67Chevy
Codez67Chevy's Avatar
Make sure the hood isn't tearing apart from the bolt holes either. Mine did that and I just welded them up did a little grinding and some repaint and Ta Da! Presto!. I also did use a marker before I took the hood off and it went right back into place. Good luck.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 07-21-2013, 09:48 PM   #9
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
If I am not mistaken, if the hood is too high in the back you need the back of the hinge go down and the front of the hinge come up. Or you might not need to adjust the front of the hinge at all.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 07-21-2013, 10:24 PM   #10
Redleg87
I had to have someone push downward and towards the rear on the hood while it was upright.. sounds weird.. and then tighten the bolts. you may be able to see where the old washers were at. helps get it close anyway.
Redleg87 is offline   Reply With Quote
Old 07-21-2013, 10:32 PM   #11
LockDoc
The Older Generation
LockDoc's Avatar
Here's the procedure posted by Huck:
To get the back down with existing hinges---open hood----loosen the three bolts that attach hinge to fender (both sides). Now push the hood up till the hinges stop moving, ---now push it open a bit more to preload the hinges. Tighten hinges. (two people make it a lot easier) now CAREFULLY lower the hood--this may take a few adjustments to get it to sit just right (height wise). You may need to adjust the hood front to rear to allow for proper clearance with the cowl.
LockDoc
Leon
Old 07-21-2013, 10:33 PM   #12
LockDoc
LockDoc's Avatar
Double post for some reason...
LockDoc
Leon
Old 07-21-2013, 11:07 PM   #13
Joesjunk
Joesjunk's Avatar
I'll grab Rick some evening and we will come buy and help you. Just let me know when
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 07-22-2013, 08:19 AM   #14
DREW67
DREW67's Avatar
It would be a honor to have you guys over.
DREW67
Old 07-22-2013, 09:14 AM   #15
Joesjunk
Joesjunk's Avatar
Text me and let me know a night that works for you
Old 07-22-2013, 09:56 AM   #16
67 chevelle
67 chevelle's Avatar
generally when the hood is high in the back , the hinges are worn , and you need new hinges
67 chevelle is offline   Reply With Quote
