Marker light Problem!!
Hey guy's
I bought some LED trailer lights and installed them on my 67gmc all work but turn signal. Both lights have a RED, WHITE and BLACK wire. RED is turn/brake, BLACK is running lights and WHITE is GROUND. When I hook up my test light to the RED then they blink as advertized but when I take the test light away the light stops blinking and just stay lit. I am assuming that I have a bad ground. Any thoughts?
67 GMC C1500 SS 4.1L if you get bored ck out my build.http://67-72chevytrucks.com/vboard/showthread.php?t=587096 |
Re: Marker light Problem!!
here's a picture of the wire's
try a electronic flasher there may not be enough resistance to make the flasher work
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
![]() Join Date: May 2010
I'm no expert, but I seem to recall reading somewhere that LEDs do not draw enough current to "trip" conventional flashers. The fact that the small addition of the test light makes them work would seem to verify this. Perhaps try different flashers or look for a flasher specifically for LEDs. Maybe someone more knowledgeable will chime in.
#5 | |
Agreed.
It's like the opposite of adding a trailer to an older vehicle with-out adding a heavy duty flasher, which make them flash too fast.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
i will have to look everything you said and get back with you on that. electronic flasher?resistance?
(Light bulb) flasher meaning flasher relay under truck dash. gatcha now just the task of finding one. thanks for the great response guy's.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I agree it needs a electronic flasher that will trip with LED lights
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Another way to do it - and I've seen it done this way - is to tap a wire off of the flasher under the dash and wire it to a bulb and holder. Like your test light, this will provide enough resistance in the circuit to make the flasher flash.
Me personally I would buy the electronic flasher.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#10 | |
i went to o'reilys and they recommended this:
it worked, all working properly for now.
#12 | |
I would skip the part of the pack that says "No wire cutting is required" and get out the soldering iron. And have a care about the part that says "LOAD EQUALIZERS GET AS HOT AS INCANDESCENT BULBS!" I'm guessing that all you're doing is wiring a resistor across the circuit - which mimics the effect of a light bulb.
Old Skool Club
![]() Join Date: Jun 2001
The part you got at O'Reilly's is designed for 88-98's with LED's. The LED's that they sell are trash, even though they are called Super Brite. The correct way to install them is parallel to the turn signal filament. What you may have done is just add resistance to the circuit which did what you needed done.
There are electronic flashers that have already been mentioned, that replace the OEM style flasher. They will make LED's operate properly. I used one in my '69, and it worked great. So, there is more than one way to fix stuff.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
