07-22-2013, 09:28 PM | #1 |
Have a question about frames?
specifically the ones circled in RED. What is the "C6P"? There are 2 different frames for a c20 and k20 131" wb...I dont understand?
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
07-22-2013, 09:32 PM | #2 |
Re: Have a question about frames?
Goin to take a stab in the dark, i'd say "heavy half" or "big 10" frames... Seems like they would make sence to be thicker and beefier know what i mean?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
07-22-2013, 10:20 PM | #3 |
More like a "heavy 3/4" -
C6P is a heavy duty frame/suspension option that bumps the GVW on a 20 series from 7200 to 8600 lbs. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-22-2013, 10:25 PM | #4 |
C6P as far as I know is GM's H.D. suspension for 3/4 ton trucks. So kind of like a "heavy half" or "Big 10" for the 3/4 ton trucks.
07-22-2013, 10:59 PM | #5 |
Agree. Couldn't have said it better myself.
K
07-22-2013, 11:00 PM | #6 |
Thank YOU EVERYONE!
07-23-2013, 12:10 AM | #7 |
So this would be the difference in semi float vs full float 14 bolts on these trucks too then??
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
07-23-2013, 12:23 AM | #8 |
I call the semi float a 5/8 ton.
07-23-2013, 12:47 AM | #9 |
That's what we always called the heavy half/ big 10s is 5/8 ton.
Posted via Mobile Device Posted via Mobile Device
07-23-2013, 01:32 AM | #10 | |
http://67-72chevytrucks.com/vboard/s...ghlight=frames Desert |
07-23-2013, 07:27 AM | #11 |
My 83 C20 camper special is rated at 8600 GVWR.
07-23-2013, 07:43 AM | #12 | |
The point of this thread was that there are two different frames within the 3/4 ton family (not the difference between 1/2 ton and 3/4 ton) - so slightly different question. K
07-23-2013, 10:35 AM | #13 | |
Yes I realize that. I was showing another thread where this frame chart came from. My 83 is 8600 GVW , I thought the designation " C6P " was a Crewcab or 3+3 frame Desert |
07-23-2013, 12:03 PM | #14 |
That is what I was thinking too was C(cab) 6P(6 passenger)...but maybe I am wrong.
07-23-2013, 12:04 PM | #15 |
Nope my standard cab has the c6p option
07-23-2013, 12:05 PM | #16 |
Scratch that...because it is listed for the 131.5" wb...a crewcab is 164" right? So yes I get it now...sorry.
07-23-2013, 12:07 PM | #17 |
Another question...SAME topic, is that chart for all years 73-91 squares? I am curious about a '76 K20
07-23-2013, 12:38 PM | #18 |
Ah - thanks. Nope - not crew or 3+3, as evidenced by your chart which shows it only with C20903 (3/4 ton reg cab 2wd) and K20903 (3/4 ton reg cab 4wd).
07-23-2013, 12:39 PM | #19 | |
The alpha-numeric was just next in line when they created the content. It can't be dissected as you are suggesting. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 07-23-2013 at 12:47 PM. |
07-23-2013, 12:45 PM | #20 | |
http://www.gmheritagecenter.com/docs...olet-Truck.pdf does not show C6P as available in 1976. So my interpretation would be "no". K
07-23-2013, 12:49 PM | #21 |
Geez, guys - sorry for being such a "Negative Nelly" today...
(lol) K
07-23-2013, 01:02 PM | #22 |
Again, THANK YOU.
