Old 04-21-2013, 10:39 AM   #1
truckdude239
truckdude239's Avatar
gas pedal mount>
Does anyone make a mount that bolts in to mount he gas drive by wire gas pedal?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 04-21-2013, 03:34 PM   #2
Daaaanz67
Re: gas pedal mount>
I actually used the original mount out of a 2006 Tahoe that my drive train came out of if you look at the picture I just kept bending the lower mount to match the floor then made two spacers for the other two mounting hole which you can't see. The spacers actually go between the pedal bracket and firewall. Also that upper mount on left theirs one just like it behind the pedal it also bends to the left. The spacers are for the upper mounts hope you under stood that. Really worked slick got it almost right in the original spot
Daaaanz67 is offline   Reply With Quote
Old 04-21-2013, 07:12 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Take a look at my build, we used a cut steel piece and a custom pedal-arm and fit it up. It gives us a little more let room because it puts thr pedal as "deep" as it can go while still Maxes out at the carpet.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-24-2013, 01:48 PM   #4
smoky02
Location: Sunny, Florida, some might call it South Alabama
Not trying to hijack this thread...but do you get much travel out of that pedal? On my pedal, closed to wide open is only like an inch of movement
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 04-27-2013, 09:07 AM   #5
awhite4557
awhite4557's Avatar
My DBW pedal is out of an 01 GMC Yukon, I combined the DBW with the base and pedal arm from my 71 and it works great and bolts up to the factory holes. It has full throttle/travel and works great.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 04-27-2013, 11:52 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I guess the "old shotgun barrel" gas pedal isn't for everyone.
Old 04-27-2013, 12:22 PM   #7
Daaaanz67
That's nice but it might shoot my eye out ha ha.
Old 07-05-2013, 04:46 PM   #8
truckdude239
this is what i ended up doing
David fuller
2000 Tahoe 5.3l 378
Old 07-05-2013, 09:55 PM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my pedal is a later model dbw like post #2. there is no metal base or shaft, they are totally composite so my welder was of no use. I have a block in place for now but like the bracket for it as posted in #2 and can see something similar as a future upgrade.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-24-2013, 02:21 PM   #10
Hart_Rod
Hart_Rod's Avatar
I used an 05-13 Corvette pedal and made a bracket thats bolts on like the LFD pedal mount.
Hart_Rod is offline   Reply With Quote
Old 07-25-2013, 09:37 PM   #11
68GMCCustom
That complete assembly (minus the fabricated base plate) is '05 up Vette?
Kurt -
Old 07-25-2013, 11:26 PM   #12
Hart_Rod
Hart_Rod's Avatar
Yes sir!
Old 07-26-2013, 08:14 PM   #13
68GMCCustom
Oh I hope I can use that on my genIV! '05 Vette.....IIRC that would be LS2 right?
Kurt -
Old 07-26-2013, 10:13 PM   #14
lynnfield
The Waco Kid
lynnfield's Avatar
Originally Posted by Hart_Rod View Post
I used an 05 and up Corvette pedal and made a bracket to bolts on like the LFD pedal mount.
Rob, this works with the 5.3's? (plug, wiring, & tac module)
lynnfield is offline   Reply With Quote
Old 07-27-2013, 03:22 PM   #15
Hart_Rod
Hart_Rod's Avatar
My motor is a Gen IV LS3, .
I'm not sure. You'll have to ask the whoever is building your harness, but I don't see why it wouldn't work.
Old 07-30-2013, 09:12 PM   #16
Mr. 250r
Mr. 250r's Avatar
I got an 05 pedal which has a massive throw for wide open and its annoying because its sit almost higher than the gas pedal i need to take a look at it because its not right lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-12-2013, 01:32 PM   #17
Hart_Rod
Hart_Rod's Avatar
"You can use a Corvette pedal instead of a truck pedal with the proper pining. Can't substitute it on a Trailblazer setup though." Quote from John at Speartech in regards to the Corvette pedal.
