Closed Thread
Old 07-23-2013, 11:48 AM   #7501
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: What did you do to your truck today!
Originally Posted by in deep 72 View Post
I got it dirty.
WOW! have fun cleaning
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is offline
Old 07-23-2013, 11:56 AM   #7502
craig7070
craig7070's Avatar
Originally Posted by In The Ten Ring View Post
Running after 5 years? Way to go dude! That gives me encouragement that I can get mine going before the fall.
Thanks people were doubting me but I showed them....LOL I just drained all the old gas out. Im going to flush out all the old oil and water out of the block.I need to bleed the brakes so I can drive it... A Coworker is going to sell me a summitt 600 cfm carb for 125.00 since his needed a 750....Score...
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles
Work in progress....Got the truck for free all original
craig7070 is offline
Old 07-23-2013, 01:39 PM   #7503
vegadesign
vegadesign's Avatar
x2 lol
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline
Old 07-23-2013, 01:40 PM   #7504
rincones
rincones's Avatar
Rincon
rincones is offline
Old 07-23-2013, 02:49 PM   #7505
jc70chevy
jc70chevy's Avatar
finally got cab off the frame
jc70chevy is offline
Old 07-23-2013, 08:09 PM   #7506
IntegratedTJ
IntegratedTJ's Avatar
Removed the A/C unit finally, after multiple failed attempts.
IntegratedTJ is offline
Old 07-24-2013, 08:19 AM   #7507
Dobster
Removed
Dobster is offline
Old 07-24-2013, 08:21 AM   #7508
Dobster
Originally Posted by rincones View Post
The truck in your sig, looks good but I cant see the video?
Dobster is offline
Old 07-24-2013, 06:55 PM   #7509
Saclandman
Saclandman's Avatar
My new pink slip arrived in the mail today! I'm the titled owner now. Yay!!!
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 07-24-2013, 08:29 PM   #7510
In The Ten Ring
I am so happy today! I got my gas tank out and it came out so easily I am STILL just pumped! (Thanks to good advice found here).
I also removed a falling apart door stop/bumper so I need to order a set of those.
Found more rust in the bottom of the cab under the gas tank spout hole. Oh ya, and I have a rust hole in my muffler too! Add that to the list....
In The Ten Ring is offline
Old 07-25-2013, 12:01 PM   #7511
sKnNyPpY
sKnNyPpY's Avatar
Replaced the pcv valve grommet in the valve cover...best $2.75 spent on Black Betty. Exhaust leak is next
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Old 07-25-2013, 12:27 PM   #7512
Mister-B
Was it running rough or something?
Mister-B is offline
Old 07-25-2013, 12:29 PM   #7513
In The Ten Ring
I ordered a bunch of parts: mostly rubber bumpers but did order the new sending unit.
Found out a new radiator from Advance Auto would be some $400.00! YIKES. I guess I'll buy from a vendor on here when the time comes.
Found a new fuel pump at Advance Auto but can't get a hold of the store....both phone lines seem to be out. So....might just go on over there today.
Old 07-25-2013, 12:41 PM   #7514
sKnNyPpY
sKnNyPpY's Avatar
The dang thing (pcv valve) would just slip out, typically when I was doing 60 mph down the hwy, Mister-B. The original grommet was all dry rotted and half of it ended up in the valve cover when I tried to replace it (I fished it out). The engine would sputter when it wasn't securely mounted, problem solved.
sKnNyPpY is offline
Old 07-25-2013, 12:48 PM   #7515
Mister-B
Ah, ok. Makes sense
Mister-B is offline
Old 07-25-2013, 01:40 PM   #7516
sharpe
Nothing yet, besides ordering some parts. Hopefully going to pick up a set of 22s for it this evening.
sharpe is offline
Old 07-25-2013, 02:02 PM   #7517
VWNate1
VWNate1's Avatar
Post Re : Engine Grommets
FWIW ;
ALL those pesky , leaky engine grommets are available in the " HELP ! " aisle of your FLAPS .
Not only will your engine run better with them in place and snug but , it'll leak less oil everywhere too as the PCV's mild vacuum helps to slow weeps & seeps .
I always take all the old rotten or blubbery rubber grommets to match them up .
They have the correct long exhaust studs and alloy nuts too .
Clean & re paint the covers when the grommets are out to make it look prettier .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-25-2013, 08:54 PM   #7518
In The Ten Ring
Today I also (after posting that above) bought some rubber hose for the fuel lines and ordered a new fuel pump from Advance Auto. I guess I might as well replace as much as I can on the fuel system while I'm working on it.
Old 07-25-2013, 10:13 PM   #7519
slow-1
slow-1's Avatar
Originally Posted by 71GeneralMotorsCorp View Post
Put new bumper, door, tailgate, chased down the wiring gremlin, replaced a starter, installed some headers and spintech Prostreets. put my posi 3;73 rear under it, and picked up a set of camaro style rallys for our trucks. One hell of a day if you ask me. haha
That was a heck of a day...did you work 20 hours on it?
For mine, I found a radiator shop that still fixes radiators and dropped off my busted radiator.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline
Old 07-25-2013, 10:14 PM   #7520
Dobster
Dobster is offline
Old 07-25-2013, 10:44 PM   #7521
70chevy10
70chevy10's Avatar
I put my coil springs in and finally got here home from my dads
1970 c10 LWB (BIG BUILD UNDERWAY) SEMA 19?
1969 GMC K2500 V6 Step Side Long Bed
2008 F250 650hp CUMMINS SWAPPED Daily Driver + too much to list
LAST DROP GARAGE, LLC.
Check the Shop out!
http://www.lastdropgarage.com
70chevy10 is offline
Old 07-25-2013, 10:49 PM   #7522
bobbydigital
bobbydigital's Avatar
found a leak in brake line and spent two hours trying to get the dang thing off. painted the grill, bumper and wheels black to cover up the poor worn out finish. had to wait for the penetrating oil to allow the line to come off and painted the bowtie on the hood to match. came out nice against the white paint
bobbydigital is offline
Old 07-26-2013, 01:26 AM   #7523
PAWS 72
PAWS 72's Avatar
Started cleaning on it after I done with the Javelin. Got a show Saturday at the church where mom and dad goes. Nobody knows they have the Javelin.
PAWS 72 is offline
Old 07-26-2013, 04:52 PM   #7524
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Let's see if I can post a couple pix :
WTF NOW ?! it allows me to select the file then says ' invalid file ' .
Screw this B.S. .
GRrrrr.......
-Nate
Geezer
VWNate1 is offline
Old 07-26-2013, 05:15 PM   #7525
PAWS 72
PAWS 72's Avatar
Screw this B.S. .
GRrrrr.......
Nate I know the feeling. I switched the resolution on my phone last night to the lowest they say and it still says that its too large. Go figure.It will be better when finished. I hope
I havent complained but I'm getting impatient and ill. But we'll survive.
I've lived without internet before.
PAWS 72 is offline
Closed Thread
