Hey guys I've been tinkering with my transmission cooling lines on my 4L60E and the bolts(?) that were taken off before wont seem to fit! I've been messing around with it for the longest time. Are these none reusable? Also could you tell me which is the inlet and outlet? Thanks!
A place for everything, everything in its place. Check out my build thread! http://67-72chevytrucks.com/vboard/s...43#post6129043 |
![]() Join Date: Jul 2013
Re: 4L60E is acting up
What bolts?
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
On the passenger side of the transmission there are two holes for the Inlet and outlet for the trans cooler/radiator. I'm using the original piece that screws in over the factory pipe and it won't fit
Top is return, Bottom is supply.
The fittings are 1/4 STRAIGHT thread. Russell and a few others make AN fittings for these.
I'm not completely sure what you are needing. The factory fittings retain the lines with a spring clip.
Maybe the treads on your fittings are gubbered up a little.
Yes that's what I'm talking about! I'm going to tinker with them today
