#7501 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: What did you do to your truck today!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#7502 | |
Thanks people were doubting me but I showed them....LOL I just drained all the old gas out. Im going to flush out all the old oil and water out of the block.I need to bleed the brakes so I can drive it... A Coworker is going to sell me a summitt 600 cfm carb for 125.00 since his needed a 750....Score... ![]() ![]()
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles Work in progress....Got the truck for free all original ![]() |
#7503 |
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#7504 |
Rincon |
#7505 |
finally got cab off the frame
#7506 |
Removed the A/C unit finally, after multiple failed attempts.
#7507 |
Removed
#7508 |
The truck in your sig, looks good but I cant see the video?
#7509 |
![]() Join Date: May 2013
My new pink slip arrived in the mail today! I'm the titled owner now. Yay!!!
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#7510 |
I am so happy today! I got my gas tank out and it came out so easily I am STILL just pumped! (Thanks to good advice found here).
I also removed a falling apart door stop/bumper so I need to order a set of those. Found more rust ![]() Last edited by In The Ten Ring; 07-24-2013 at 08:40 PM. |
#7511 |
Replaced the pcv valve grommet in the valve cover...best $2.75 spent on Black Betty. Exhaust leak is next
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
#7512 |
#7513 |
I ordered a bunch of parts: mostly rubber bumpers but did order the new sending unit.
Found out a new radiator from Advance Auto would be some $400.00! YIKES. I guess I'll buy from a vendor on here when the time comes. Found a new fuel pump at Advance Auto but can't get a hold of the store....both phone lines seem to be out. So....might just go on over there today. |
#7514 |
The dang thing (pcv valve) would just slip out, typically when I was doing 60 mph down the hwy, Mister-B. The original grommet was all dry rotted and half of it ended up in the valve cover when I tried to replace it (I fished it out). The engine would sputter when it wasn't securely mounted, problem solved.
#7515 | |
Posted via Mobile Device |
#7516 |
Nothing yet, besides ordering some parts. Hopefully going to pick up a set of 22s for it this evening.
#7517 |
FWIW ;
ALL those pesky , leaky engine grommets are available in the " HELP ! " aisle of your FLAPS . Not only will your engine run better with them in place and snug but , it'll leak less oil everywhere too as the PCV's mild vacuum helps to slow weeps & seeps . I always take all the old rotten or blubbery rubber grommets to match them up . They have the correct long exhaust studs and alloy nuts too . Clean & re paint the covers when the grommets are out to make it look prettier .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#7518 |
Today I also (after posting that above) bought some rubber hose for the fuel lines and ordered a new fuel pump from Advance Auto. I guess I might as well replace as much as I can on the fuel system while I'm working on it.
#7519 | |
For mine, I found a radiator shop that still fixes radiators and dropped off my busted radiator.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#7520 |
#7521 |
I put my coil springs in and finally got here home from my dads
![]() Posted via Mobile Device
1970 c10 LWB (BIG BUILD UNDERWAY) SEMA 19? 1969 GMC K2500 V6 Step Side Long Bed 2008 F250 650hp CUMMINS SWAPPED Daily Driver + too much to list LAST DROP GARAGE, LLC. Check the Shop out! http://www.lastdropgarage.com |
#7522 |
found a leak in brake line and spent two hours trying to get the dang thing off. painted the grill, bumper and wheels black to cover up the poor worn out finish. had to wait for the penetrating oil to allow the line to come off and painted the bowtie on the hood to match. came out nice against the white paint
#7523 |
Started cleaning on it after I done with the Javelin. Got a show Saturday at the church where mom and dad goes. Nobody knows they have the Javelin.
#7524 |
Let's see if I can post a couple pix :
WTF NOW ?! it allows me to select the file then says ' invalid file ' . Screw this B.S. . GRrrrr.......
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() Last edited by VWNate1; 07-26-2013 at 04:55 PM. Reason: No Pix Appeared |
#7525 | |
I havent complained but I'm getting impatient and ill. But we'll survive. I've lived without internet before. |
