Old 03-31-2013, 04:35 PM   #101
Ford Assassin
Ford Assassin's Avatar
Re: ls turbo build
Originally Posted by 85burb View Post
That is intended to work with the AC compressor in the stock location.
That will place the turbo in the exact same spot the AC compressor when using the Kwik Performance/Vintage Air bracket.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 03-31-2013, 04:40 PM   #102
prostreet1967
prostreet1967's Avatar
Re: ls turbo build
I'm gonna mount mine in the middle up front. If camaro guys can surely I can. Gonna run. 76mm for a while with truck manifolds. What size is your turbo?
prostreet1967 is offline   Reply With Quote
Old 03-31-2013, 05:19 PM   #103
69trk
69trk's Avatar
Re: ls turbo build
bw s475 t6 flange. Ill look into a ac bracket that will hold the ac compressor mid mount...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-01-2013, 10:08 AM   #104
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: ls turbo build
Easier said than done. Have you actually set the turbo in between the engine and radiator? I have. It didn't fit.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-01-2013, 10:25 AM   #105
prostreet1967
Re: ls turbo build
no i havent yet. just figured if camaro guys can we should be able too. been kinda worrying about my turbo being so heavy i was wondering how to mount it. my turbo ended up being a 88mm. its a little to big but got it cheap so will try it.
sorry 69trk not trying to hijack. i will be following the build.
Old 04-01-2013, 01:33 PM   #106
prostreet1967
Re: ls turbo build
http://www.theturboforums.com/thread...-1970-c10-s475
ck this out, i like how he ran his merge and his mounting of the turbo.
Old 04-01-2013, 03:01 PM   #107
Ford Assassin
Re: ls turbo build
Still wont clear aftermarket AC compressor placement.
Cable
Old 04-01-2013, 04:07 PM   #108
Wasted Income
Boosted Member
Re: ls turbo build
No, but mine will
Turbo diesel
Old 04-01-2013, 05:21 PM   #109
prostreet1967
Re: ls turbo build
Originally Posted by 69trk View Post
Look at all the room in front of the engine... Turbo should be fairly easy
How far back is the engine? Thinking bout sliding mine back as far as possible
Old 04-01-2013, 10:39 PM   #110
69trk
69trk's Avatar
Re: ls turbo build
Originally Posted by Wasted Income View Post
No, but mine will
Could you make me one of those ac compressor brackets?
1.58- 60'
11.37- 1/4 @115.81
Old 04-02-2013, 09:20 AM   #111
Wasted Income
Boosted Member
Re: ls turbo build
I didn't have time to make the setup myself. I got the brackets from a guy on LS1tech that goes by fox12303
It's about 3x the cost of the Kwik setup, but worth it for my application...IMO.
Turbo diesel
Old 04-15-2013, 11:33 PM   #112
aaronr
Re: ls turbo build
I'm currently building a twin turbo set for my 67 chevy truck.
67-C10 under construction
2002 ECSB Chevy 5.3l with t-70 turbo
216/218 114lsa and 4l80E Built trans w/ 2500 stall
aaronr is offline   Reply With Quote
Old 04-22-2013, 08:32 PM   #113
69trk
69trk's Avatar
Re: ls turbo build
Installed my wilsons 90mm throttlebody. Had to make a wheel bracket for the throttle cable to work. Installed the starter, alternator and most of the hydraboost unit. Finally received all my guages so I can start back to wiring the truck.
1.58- 60'
11.37- 1/4 @115.81
Old 05-19-2013, 07:18 PM   #114
69trk
69trk's Avatar
Re: ls turbo build
Finishing up the wiring harness. Also installed the fuel rails and 120lb injectors. Finished the dash and guages. Making some progress very slowly....
1.58- 60'
11.37- 1/4 @115.81
Old 05-19-2013, 07:31 PM   #115
prostreet1967
Re: ls turbo build
Looking good been wondering how your project was coming sinc I'm just collecting parts
Old 06-17-2013, 04:07 PM   #116
mcbassin
Still Learning
mcbassin's Avatar
Re: ls turbo build
Very cool project! Love the plans for this one. Subscribed....
Old 07-24-2013, 01:26 PM   #117
craig7070
craig7070's Avatar
Re: ls turbo build
Subscribed...Great Job and Info so far
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles
Work in progress....Got the truck for free all original
craig7070 is offline   Reply With Quote
Old 07-24-2013, 10:32 PM   #118
69trk
69trk's Avatar
Re: ls turbo build
Thanks. My dad passed away last month and I have alot to do. Just sold his 41 to help put my mom in a home.. sucks when I have any free time I work on my old truck. About to finish the fuel lines. Then finish mounting the computer and wiring harnesses..
1.58- 60'
11.37- 1/4 @115.81
Old 07-25-2013, 04:06 PM   #119
craig7070
craig7070's Avatar
Re: ls turbo build
Sorry for your loss....
Old 07-25-2013, 04:10 PM   #120
Hart_Rod
Hart_Rod's Avatar
Re: ls turbo build
Condolences to you and your family.
Hart_Rod is online now   Reply With Quote
Old 07-28-2013, 11:18 AM   #121
69trk
69trk's Avatar
Re: ls turbo build
Got the ronfrancis wiring all installed and everything works except for the dome light when i open the doors I also got the fuel lines finished, just need to buy a couple gallons of gas and cycle the fuel thru the filter to make sure everything is clean.... Then i'll plug the oil feed and return so i can put some oil in it and crank it to lubricate the engine.... next thing is ordering my ac system and installing radiator and mounting ecu and running the holley hp wiring.... slowly getting there... I would upload pics but for some reason all my file types are to large even after i shrink them...
1.58- 60'
11.37- 1/4 @115.81
Old 08-20-2013, 08:43 PM   #122
69trk
69trk's Avatar
Re: ls turbo build
Trying to post pics. Mounting ecu in center console.
1.58- 60'
11.37- 1/4 @115.81
Old 08-20-2013, 08:51 PM   #123
69trk
69trk's Avatar
Re: ls turbo build
Trying to figure out how to mount intercooler. Looks like I will have to modify inner grill in order for ac condensor to fit..
1.58- 60'
11.37- 1/4 @115.81
Old 08-20-2013, 08:59 PM   #124
69trk
69trk's Avatar
Re: ls turbo build
Engine bay is starting to look pretty good. Need a few more sensors and plug wires and im buying the holley coil covers..
1.58- 60'
11.37- 1/4 @115.81
Old 08-20-2013, 10:50 PM   #125
mcbassin
Still Learning
mcbassin's Avatar
Re: ls turbo build
Hey, sorry to hear about your dad and Mom. The engine bay looks great. Keep the updates coming.
