Old 07-12-2013, 09:05 AM   #151
Red Foreman
Red Foreman's Avatar
Re: 56 GMC Aussie Style
Some more random shots of the tub, I'm happy with its rear ride height.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 07-12-2013, 09:11 AM   #152
Bubba54
Truck looks great. The 348 really took me back, when i was a kid a guy had one down the street. I think it was in an impala. Anyway, cool setup.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 07-12-2013, 09:36 AM   #153
Red Foreman
We also mounted the front clip on today, I hardly bolted it on at this stage but I got so excited I cracked the old Canon back out to take more pics.
I guess I was just so happy that its starting to come together, also front ride height is were I expected with the stock 403/olds Firebird coils.
I expect it to drop another inch to end up level all round by the time the heavy GMC bumpers, hood, rad, batt etc.. are fitted, note the front rims mounted on six lug Camaro/Firebird disc rotors.
My Build 56 GMC
Old 07-12-2013, 09:53 AM   #154
Red Foreman
Shawn
Thanks Shawn, the 348 actually looks at home in the engine compartment, it kinda looks like it was born with it from new.
My Build 56 GMC
Old 07-12-2013, 12:47 PM   #155
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-13-2013, 08:41 PM   #156
Red Foreman
Thanks Kim. I got the shifter in a couple of days ago its a 23" floor mount Lokar, its all hooked up & works a treat!
My Build 56 GMC
Old 07-24-2013, 05:21 PM   #157
Coronas56
Coronas56's Avatar
Looking good Red. Keep up the good work. ..
Semper Fi!
Coronas56 is offline   Reply With Quote
Old 07-24-2013, 09:22 PM   #158
Wheelie
Looking awesome! Great work your doing.
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 07-24-2013, 09:51 PM   #159
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by Red Foreman View Post
...the stainless spill tray around my fuel filler is a dress trim used on CJ model Jeeps, it worked a treat!
Nice idea, I like that. It's originally for the Jeep door handle?
If so, I assume you have to drill the large diameter hole for the filler?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-25-2013, 10:35 AM   #160
Red Foreman
Thanks fella's, I appreciate the compliments!
Dan, the tray I used is actually a stainless fuel cap dress trim surround on CJ series Jeep's. I stumbled across them at a local Jeep parts supplier.
I had to open the hole out to slip over the 2.5" filler neck that I used in the tank, I have the lower part slanted towards the rear & drilled a little drain hole for spillage or water accumulation.
My Build 56 GMC
Old 07-25-2013, 10:51 AM   #161
dubie
dubie's Avatar
this is one damn fine build thread. I love the attitude this truck already possess's. A great stance goes a long way
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 07-25-2013, 11:09 AM   #162
Dan in Pasadena
Oh, ok. For some reason I thought it was he door handle surround. I even went online to a Jeep parts supplier and of course I couldn't find it...I was looking for the wrong thing.
Drilling the small hole was a smart idea. I see you put some kind of door edge guard(?) around the hole I assume to minimize any rattling between the fill tube and this pan. How did you slant it? It looks like it sits flush with the wood from above, but I imagine you shimmed one end with something?
Old 07-25-2013, 11:22 AM   #163
Dan in Pasadena
Ok, I found it:
http://www.jeep4x4center.com/gas-tan...-5463803m.html
Posted just in case someone else comes along later and is looking for it. A little pricey for what it is, but nice.
I like THIS one too, but it's even more expensive:
http://www.jeep4x4center.com/kentrol...yle-30586.html
Old 07-25-2013, 05:44 PM   #164
Red Foreman
Thanks Dubie, I've been keeping an eye yours as well, as for the stance I'm pretty happy the way it sits & I still have 3.8" of travel in the rear, front springs are stock Firebird.
Drilling the small hole was a smart idea. I see you put some kind of door edge How did you slant it? It looks like it sits flush with the wood from above, but I imagine you shimmed one end with something?
Dan, the trim sit flush but if you look closely there is slant built in to the lower section around the hole of the surround, I could of sat the taper either way but I chose to run it towards the back, it just looked/flowed better.
Yes your correct, I opened the hole a little more & fitted a rubber bead in around the trim case of movement or vibration.
My Build 56 GMC
Old 07-25-2013, 11:17 PM   #165
Dan in Pasadena
Thanks Red.
Let me echo what dubie said: you've done a fine, fine job on the truck. It's obvious you take care to do EACH nicely. I like that and hope to do much the same with mine, but I confess everything I do doesn't always come out exactly like I'd have wanted it to.
Old 09-06-2013, 10:25 AM   #166
mknittle
mknittle's Avatar
Looking real nice Red
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-06-2013, 11:52 AM   #167
alaska gasser
alaska gasser's Avatar
I like that you went with a 348 as I'm putting one into my '48. Did you find it there, or did you pick it up in the States?
alaska gasser is offline   Reply With Quote
Old 09-07-2013, 07:40 PM   #168
Red Foreman
Thanks Red.
Thanks Dan, I have been watching yours and its coming along just fine!
Thanks mate!
I picked it up from a scrap guy in upstate NY and had it shipped here, it is actually a 63 truck motor. There's before & after pics of it on page 1 & 3.
My Build 56 GMC
Old 12-20-2013, 04:21 PM   #169
Red Foreman
Hi Fella's, haven't been around much lately apart from occasionally looking in the main board. Anyway I finally got my seat back from the upholsterer, its done in ivory & turquoise marine vinyl. Here is before & after pics.
My Build 56 GMC
Old 12-20-2013, 04:38 PM   #170
Denee007
Denee007's Avatar
Gee~ that is one gorgeous seat!! Good job!
dne'
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 12-20-2013, 04:43 PM   #171
Red Foreman
Thanks dne, your Apache has come along very nicely btw!
My Build 56 GMC
Old 12-20-2013, 04:45 PM   #172
Denee007
Denee007's Avatar
Thank you for that wonderful compliment! I kind of miss working on it! I need to take something apart soon or I'll go stir crazy!
Old 12-20-2013, 06:27 PM   #173
Kim57
Kim57's Avatar
Very nice seat.
Kim
My build thread
Old 12-20-2013, 11:37 PM   #174
Red Foreman
I here ya Denee, now that I'm getting close myself I'm kinda ich'n for the next project but wife...I mean money may be an issue?
Originally Posted by Kim57 View Post
Very nice seat.
Kim
Thanks Kim!
Seat in!!
My Build 56 GMC
Old 12-21-2013, 12:02 AM   #175
Red Foreman
While the Camera's out here's a couple more random shots of the cab. Dash cluster back in, all wiring done.
My Build 56 GMC
