Old 07-27-2013, 08:49 AM   #1
Desert1957
Desert1957's Avatar
Bouncing gas gauge qustion
Thread should say "question"
My 83 has dual tanks, after fuel level gets down below 3/4 the gauge seem to be constantly moving around and bouncing. Is there a fix for this? or is it a common problem.
My 87 with the electric fuel pump takes a different sender I know, but does not have any issues with the gauge.
Desert
Desert1957 is offline   Reply With Quote
Old 07-27-2013, 11:21 AM   #2
Ziegelsteinfaust
Re: Bouncing gas gauge qustion
Mine has a similar problem, and I think the problem is the sending unit on mine.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-27-2013, 01:13 PM   #3
hatzie
Moderator
hatzie's Avatar
Solid tank and gauge grounds and solid sender wire connections...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-27-2013, 02:24 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
I think the fuel just sloshes around more when low
As I recall some gas gauges had a resistor to move slower to prevent bouncing
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-27-2013, 05:09 PM   #5
Skunksmash
Skunksmash's Avatar
GM really screwed the pooch on this one. Not only did they mess up on the gauge side of things, they messed up on the sending unit side as well. The way I fixed it, was to buy a gauge from autometer. It won't accept the wildly fluctuating 0-90 ohm signal from the sending unit, so easily. It waits before it adjusts the needle. This cuts out most of the wavy needle problem, though you will still see it move from time to time.
To truly fix the problem, you also have to get a tank with better baffles in it, such as the newer ones with that big piece of foam in there.
http://www.chevyclassicsclub.com/the...ry-1965-newer/
Skunksmash is offline   Reply With Quote
Old 07-28-2013, 07:21 AM   #6
Desert1957
Desert1957's Avatar
Nice article
Old 07-28-2013, 12:30 PM   #7
slam59
My wife's 77 3/4 ton with dual tanks does the same thing. That needle bounces all over the place ALL the time. Gonna have to try that Autometer gauge.
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 07-29-2013, 02:01 AM   #8
PAWS 72
PAWS 72's Avatar
I was thinking bad ground or connection.I've been wrong before too.
PAWS 72 is offline   Reply With Quote
Old 07-29-2013, 10:15 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
When i got my 78 Jimmy it did this
I read up on it decided to live with it
when i changed to the stock cluster with tach, it went away
when i wired the cluster up i had to add a ground for the gauge
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-30-2013, 07:21 PM   #10
Skunksmash
Skunksmash's Avatar
Originally Posted by Desert1957 View Post
Nice article
Yeah I used to hate that dang wavy needle. Its like not even having a gas gauge lol. There are some people that claim you can get lucky buying a high quality, ACdelco brand sending unit (that whole apparatus) and it will fix the wavy needle. Some have done it and got lucky, others bought the same thing and had no results.
I like the idea about the ground. I always thought there had to be a way to let the signal through, but just do it once per minute. Instead of 6 times a second. That way, the needle would seldom ever be seen moving, but the gauge would still work just fine.
Old 07-30-2013, 09:34 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
just to add
it was idiots to tach/gauges in the 78
i read people had issues with spectra senders
I can see a spectra stamp on the 78 tank assumed it was a spectra sender
but in the 79 I went with a spectra tank and sender and it didn't bounce before or after
John
