62 body swap
I have a 62 chevy 1/2 ton short bed. The chassis is about junked I was wondering if the body would fit an 84 suburban chassis? Thanks
Posted via Mobile Device |
60-66 Nut
Re: 62 body swap
The Suburban frame is supposed to work better than a truck frame, but I still don't recommend it. This question gets asked quite frequently and I most always recommend against it unless you're wanting to buld a lifted 4x4. Here's a thread I started a couple years ago.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023 If you're in need of a frame, I would look for a '63-'72 frame and transfer the front suspension, and whatever else you need from the Suburban.
Re: 62 body swap
Thanks I appreciate all the help I can get
