#301 |
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
This is so cool! The video is awesome and sounds like a minor setback for your skills...great looking blazer so far.
Posted via Mobile Device |
#302 |
![]() Join Date: Apr 2005
Jeff woul you mind PMing me your number and a good time to call you? I would like to discuss fuel systems an oil catch cans....
. Thanks,Rob 8502910499 Edit: your PM box is full. Posted via Mobile Device
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#303 |
bump
#304 |
Boosted Member
Rob, I emptied out my inbox. Fire away.
Still been too busy/lazy to swap out motors, so I've been beating around on the hurt one. I set up a local hot-rod cruise every week, and last night I got a couple of nice kills via some shennanigans on the cruise. ![]() First up is my buddy's 996 911 Turbo. It's got a tune and exhaust and some other goodies and has been converted to RWD. Got him from a 40-120 roll, and was reeling him in from a dig until my tires went up in smoke. ![]() ![]() Next up was another buddy's 2013 SRT-10 Viper. We went from a 50 mph roll, and from a dig, and I walked him pretty hard during both. Needless to say, I'm pretty happy how the blazer is running...even on 3 hurt holes ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#305 |
![]() Join Date: Dec 2006
Nice kills, we need some videos of it
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#306 |
Boosted Member
Sadly I was by myself, and they were impromptu races...so no vid
![]() However, there were about 10 witnesses behind us, lol.
#307 |
2WD Jimmy
hows the bad cylinders holding up?
#308 |
Boosted Member
So far so good I guess. Haven't had any chunks blast through the turbo yet...haha.
#309 |
Can you share some info on ms3? Does it have iac control? Do you need iac if not running ac? What came with ms3 I really like those bulk heads. Thanks.
#310 |
PROJECT 7DEUCE
Nice job should run real well when ya get a new bullet in her..
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#311 | |
Boosted Member
Everything you've never wanted to know about MS3. http://www.ms3efi.com/ http://www.diyautotune.com/catalog/m...ae7d62a3186290 The bulkhead connectors came from the local Cat dealer. Thanks. Got a new custom turbo cam from Tick Performance waiting to go into the new engine. What's in there now is "ok", but i wanted a cam matched to my setup.
#312 |
Do you happen to know the part numbers? i called local CAT dealer and they were lost. the ones they did price me were 45 for male and 45 for female.
#313 | |
Boosted Member
Plug Caterpillar 9X-0401 $46.39 Receptacle Caterpillar 9X-1343 $42.46 Receptacle Caterpillar 214-4208 $80.68 Plug Caterpillar 160-7689 $34.01 16-18-20 AWG Pin Deutsch 0460-202-16141 $31.35 16-18-20 AWG SocketDeutsch 0462-201-16141 $42.00
#314 |
![]() Join Date: Aug 2010
dream build! right on!
#315 |
Hey so how did that Heidt pressure regulator valve work out? I just ordered one after reading that the hydroboost likes 3.5gpm/1500psi and the Mustang rack likes less than 2gpm/800psi. Hmmm, and how did you find out about this valve? I've been searching for days for an answer to this problem until I stumbled upon some obscure write up someone did and then as soon as I saw a picture of the valve and then I remembered seeing it in your build. But nobody seemed to have an answer to this problem, not the place I got the booster from, the company that made the rack, companies I called about pumps, even Heidt said they wern't aware of using it to regulate the pressure after the hydroboost and before the rack. How did you dial it in? Just play with it until things seem to work best? Did you use a high output pump? My understanding is that GM type II pumps put out somewhere around 2.5gpm/1000-1200psi which I'm told is kinda low for the hydroboost. Anyway this seems to be this unknown magic solution to this problem.
#316 |
Boosted Member
I didn't end up using mine...you should return yours and buy mine, complete with fittings. I'll cut you a deal.
#317 |
Boosted Member
[QUOTE=Wasted Income;6044987]Well as they say, the devil is in the details. I had more time in coming up with radiator and heater hoses that will work, than I did in the whole hot-side...
Got the downpipe fabbed up. Turbo outlet is 5", and I reduced to 4" right off the flange. I used a band clamp instead of welding the last piece for several reasons. First off, I'm not sure if I want it to exit there for sure, long-term. Secondly, it may be way too loud and require a muffler (which is ultimately did....lol). Lastly, any rework is one less thing to cut apart. ![]() Had to get creative on the lower radiator hose, since the crossover and merge are fighting for real estate with the hose. I ended up cutting the lower radiator neck back, and re-welding it...reducing it from 1.75" to 1.5", with a tight bend coming out to clear the exhaust. A nice benefit is that both end of the radiator hose are now 1.5" instead of being staggered. I went with the stainless steel flex hose for the bulk of the lower hose, to reduce the chance of damage or melting from heat. ![]() ![]() Couldn't really go above the frame, or below the frame with the turbo oil drain...so I went through it with a -12 AN bulkhead fitting. ![]() Heater hoses were a bit of a challenge as well, since the pass right between the downpipe and the manifold. The waterpump outlet is also very tight to the merge, which required molded hoses with 90s on them. I used a reflective heat wrap that is similar to what we use at work on our aftertreatment modules to shield fuel lines and such from excessive heat. ![]() Lastly here's a quick vid showing one of the coolest features of the Megasquirt. Logging and tuning on my phone, via Bluetooth. Took a little vid while I was burping the cooling system.
#318 |
MEMBER OF THE JUNK MAN CLUB
lookin good.
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
#319 |
Boosted Member
Ooops, lol. Was trying to edit that post and ended up re-posting it.....doh.
Anyway, here's an updated video. Still on the hurt motor.....haha. Turbo LS vs Turbo LS
#320 |
#321 |
Boosted Member
Rumor has it that the Thunderbird PS rack is more tolerant of higher pump output pressure than the old Mustang II racks. I decided to risk it.
No Fcks Given.
#322 | |
Anyway, sounds to me like something that would be a good thing to use. |
#323 |
Boosted Member
Got some new wheels on the way....here's a photochop that a guy did for me.
18" Centerline Lazers...gonna put some M/T drag radials out back on them.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 09-09-2013 at 11:26 AM. |
#324 |
been following this build... you have some mad skills!
love the wheels...
Ed will be known as the Tiger Woods of the integration business |
#325 |
2WD Jimmy
Those centerlines are perfect.
| Bookmarks |
