Old 07-24-2013, 09:36 PM   #1
GM-power
GM-power's Avatar
weatherstripping..
Bought a door weatherstipping kit yesterday and itll be here soon. My main question is how does the cab to door and the door gasket go on? Thinking it glues on, if so how do install it? Also I got a lock strip for my new back glass; its a roll that is enough for one use. Do I cut it at the bottom to corners of the gasket? Think thats all for now and thanks in advance!!
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 07-25-2013, 09:09 AM   #2
Jonboy
Slots go on anything!
Re: weatherstripping..
The cab to door gasket sits over the pinch weld. It will be a little long, so make sure it is seated fully before you cut it. I like to use a rubber mallet for persuasion. The lock strip should be cut to fit as well. It probably doesn't go all the way to the corner, but under the corner pieces.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 07-25-2013, 09:30 AM   #3
Brockwaykid
Brockwaykid's Avatar
Make sure you leave about 2in extra on the cab-door gasket, if you dont, when it shrinks it will create a gap, which makes noise...
Jeff Shaw
2003 Chevy 2500HD LB7 Duramax
Brockwaykid is offline   Reply With Quote
Old 07-25-2013, 06:46 PM   #4
GM-power
GM-power's Avatar
So ill need to remove the interior trim to put the cab to door gasket on? So do I glue it onto the pinch weld?
Old 07-28-2013, 10:41 PM   #5
GM-power
GM-power's Avatar
Put the backglass in friday and did all the weatherstrippinh on the drivers side. Found that the rear run channel bolt pulled the sheet metal around it out, no wonder the window wobbled around so much haha. Got a washer and fixed that problem. Its odd how quiet it is... cant wait to do the passenger side!
Old 07-29-2013, 06:27 AM   #6
79Betty
79Betty's Avatar
Weather stripping is on my to do list as well. Just driveshafts exhaust and axle seals come first lol. What kit did you get? Fit good?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-29-2013, 07:19 PM   #7
GM-power
GM-power's Avatar
I believe there a vendor here, I bought mine from precision restoration parts. Great quality and fit just like the originals!!!
