Old 07-29-2013, 08:44 PM   #1
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Do I need power disc brakes
I had the same concern over my '55 because I have too radical a cam to develop enough vacuum to operate a booster and after thinking on it awhile, I decided I didn't want to use a hydrovac system.
Any number of guys over on the HAMB told me a manual disc brake system will work just fine and since I already own a CPP disc brake kit, I went looking and bought the frame mount dual master cylinder and bracket. Haven't installed any of it yet because I'll need to run new brakes lines and I don't have the tools to bend it myself....yet!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-29-2013, 08:52 PM   #2
Midgets50
Midgets50's Avatar
im assuming you dont use the brake lines that you can easily bend by hand
Midgets50 is offline   Reply With Quote
Old 07-29-2013, 08:59 PM   #3
OrrieG
OrrieG's Avatar
When I installed my 4wd with disc/drum set up in 1985 (74 K10 donor) I did not use a booster and could lock up the wheels in an emergency. This time I added a booster and PS so my wife can drive the beast.
Old 07-29-2013, 11:32 PM   #4
Dan in Pasadena
Thumbs up Re: Do I need power disc brakes
I've never installed ANY brake lines, so I didn't know there were any you could "easily bend by hand". What are they called or what material do I want them made from? Even if I can hand bend them, I'd want them to look pro, not fly-by-night.
Fabguy, Extremely generous of you. I really do want to get to see your shop. As I posted above, my truck is locked up til I get back from vacation about August 9th. THEN, I've gotta go through the whole routine: load the camper on the dually, pull it out, out comes the '55, in goes the boat, back goes the dually, unload the camper again.... good problems to have I suppose but it tires me out just thinking about it!
I've been wanting to pull the bed since I took a Sawzall to the old wood so I can thoroughly clean and prime/paint from the cab back. We'll see. Thanks Mike for the heads up on using pre-flared lines. Would save me a lot of headaches and cash cause a GOOD flaring tool is $$$.
Old 07-29-2013, 09:36 PM   #5
fabguy
Elev8r Man
fabguy's Avatar
I have the tubing bender if you need to use it Dan. It isn't really expensive model but it gets the job done. As for the flare tool, The lengths I bought at Oreally? seemed to work great. You outta stop by the shop one day and see what I did with mine and pick up the tools to do yours.
LMAO, And YES, it was an @$$ puckering ride. that was when I decided I needed to go through the truck. I was shaking for about 1 hrs if I remember right. That was about 16 yrs ago. I drove the truck for a couple years and had never pounded on the brakes that hard.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
