Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-01-2013, 10:54 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Crank case moisture
Gotta agree with that Shaun. When you pull down a motor that has been accumilating water from a weeping head bolt or cracked casting.... where do you see the milky accumilation! I know in yesteryear motors we had metal intakes / valley covers (where your plastic?) and maybe the heat-soak of the aluminum/iron cast intake cooked moisture away better,,,,,, but the 'milk' was always in the rocker covers,,,, the highest point.
I sure can see your delimma in finding a place to put a fitting into the stock LS rocker covers.
But just a thought here. My LS sandrail motor has a (for lack of better terms) steam bleed-tube running between the heads because we have no water cross over up high on the LS. I can't help but believe we have a similar 'lack of flow' in crankcase vapors traped up high in the motor also. Pulling vapors 'down' from one rocker cover, through the crankcase,, then up and out the other rocker cover.... Well you see where I'm headed there. Some sort of cross-connection between the rocker covers might be worth investigating for you alky guys??? It would still create negative pressure in the entire motor, but evacuate the top end first.
Just a thought
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
