Transmission cooler
I have a transmission cooler for sale in the misc parts section. It is a derale aluminum external cooler unused and almost 1/2 the price. Just thought some of you guys swapping might not think to look there.
Transmission cooler
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Truck and auto performance nut
Re: Transmission cooler
how well do those cool?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Not sure, never used it. I bought it off 68shortstep when he worked on my harness. Its what he used?
I'll take it.
meowMEOWmeowMEOW
I've heard they work well in conjunction with the in-rad cooling loop, or if mounted in a high-flow area.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Any idea if they can be used as an alternative to the radiator? I've thought about using one of these but there's not a lot of info on them out there
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
meowMEOWmeowMEOW
If you intend on running a stand alone cooler (I chose to, my radiator didn't have a provision for the trans), I would go with a "radiator style" FAN COOLED unit. Most unit don't get enough airflow to completely cool the trans themselves, especially being mounted behind a radiator. Keep in mind that standing still, a non-fan cooler gets no air movement and will diminish any cooling ability it afforded. Sitting in a staging lane with your trans cooking isn't fun.
meowMEOWmeowMEOW
I've had a couple of folks say these new heat sink style work well enough to be a stand alone. Not sure I believe it...so I thought I'd try adding one and/or use it for something else if needed.
Any pictures of it mounted? I'm having a tough time trying to figure out where to mount mine.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
I have the same one mounted under the bed....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
meowMEOWmeowMEOW
Its a weird angle, and I can't get a picture with the bumer on. Its in between the front frame horns facing down.
![]() My build has a couple more pics of the install.
![]() Join Date: Apr 2005
What's the part number and price? Have you put a temp gauge on it to see how it cools?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 | |
meowMEOWmeowMEOW
Oh your just assuming I have a massive archival of every cent I've spent on the truck? I totally do; from jegs 259-13270 electra cool trans cooler 145.99 (1) 555-100001 #6 Straight hose end 4.99 (2) 9.98 555-100021 # 6 90* hose end 11.99 (2) 23.98 555-100911 #6 Hose 6ft 26.99 (2) 53.98 Plus the specialized 4l80e style AN fittings, but I had to order those elsewhere, I can dig up the source if need be. I don't have a trans temp gauge but I can tell in stop and go traffic that it helps a good bit. Trans keeps cooler so I notice a little slower buildup of heat in the engine bay in traffic/staging etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 07-29-2013 at 03:11 PM. |
#16 |
mine has a fan switch that comes on at 180* as for how hot it gets I'm not sure, but it never usually runs for a long time....
#17 |
#18 |
Looks like a good unit. I have to be honest, I just used the factory external tranny cooler that the donor escalade came with. I ran the lines to the stock escalade radiator, then to the cooler just like factory. Made some brackets to mount it in front of the AC condensor. The little I have driven the truck around it stays right around 160-175. About the same as my 2012 tahoe tranny does.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#19 |
meowMEOWmeowMEOW
I don't put mine through the radiator, so anything less than fan cooled and I wouldn't be doing myself any favors.
