#26 | |
Re: weather strip question?
live like you are dying ![]() |
#27 |
ok been looking thru threads and found some talking about using late model weather stripping on our 60-66 and the ones i did find all said to use it off of a 87-97 dodge dakota. they claim it works wonderfull, is push-on only took a few min to install, and was dirt cheap ( best reason of all ). they said would only have to trim about 3" off. i am still hoping someone else chimes in on this subject that has used it. i will be looking for one to swipe next visit to junkyard just to try if nothin else...
#28 |
I know the 2001-2007 chevy trucks have the push on weather stripping and the edge looks the same as the old trucks. It wouldn't be hard to find one and try it, they will be longer.
#29 | |
![]() Join Date: May 2009
#30 |
i called local chevy dealership to see about 01 weatherseal but they dont keep anything on hand would have to be special order so you would have to take a look and inspect one at a junkyard or if you happen to know someone that has one of those trucks and is willimg to let you pull theirs off ( like that is going to happen ) lol...
#31 |
could someone post up a pic of what the rocker wirh lip for seal is supposed to look like before seal is on so i can see how far off mine is and what i might have to do to fix
#32 |
to top
#33 |
come on guys, surely someone has a photo of what the rocker is supposed to look like before putting weather seal and sill plate down that they can post. need up close photo so as to see what it looks like to compare to mine.
#34 |
![]() Join Date: Sep 2011
Post #554 on this page will give you a couple of different angles of what it should look like.
http://67-72chevytrucks.com/vboard/s...336653&page=23
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#35 |
thanks MisterC took a look at that but when blow up photo to see up close it blurs out...really needing a up close photo to see lip and channel behide it if there is one ant voth corners and middle..
#36 |
Look through some of the build threads. The rocker replacement is one of the most common repairs made. I'm sure you'll find a good shot there. Try searching "rocker replacment" and see what that yields for you.
#37 |
well looked at some photos and best i can tell i am going to have to weld a lip on for tje weatherseal to slip onto. any ideas?
#38 |
bump
#39 | |
#40 |
floors and rockers are all solid so would hate to cut out all good metal just for a lip
#41 | |
#42 |
yeah...makes no sense what so ever
#43 |
I looked at an 05 cab I have in the back and it has door seals on it, I'll try to get some pics by the weekend.
#44 |
It's actually the "inner rocker" that has the door seal lip on it... Ask me how I know...
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
#45 |
#46 |
Oh Vernski, I shouldn't have gotten your hopes up... It's the same old rerun; boy decides to restore truck by himself only to realize that every blessed piece of sheet metal below the doors needs to be replaced... I am now intimately familiar with every curve and crevice in these cabs and their supports and I am still not done!!
#47 | |
#48 |
I found this link for Chevy & GMC weather stripping I don't think it's self-stick though..Vernski
![]() http://raybuck.com/c-54796-weatherst...therstrip.html http://www.ebay.com/bhp/universal-weatherstrip The ebay link is peel & stick Last edited by Vernski; 08-02-2013 at 09:54 PM. Reason: add link |
#49 | |
#50 |
I looked at the link you provided. They don't sell the kit for a 60-63 or 64-66. So what were you planning to buy from them?
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
