Just like to part out trucks!!
Big block motor gurus, info help???
Can anyone help me out and tell me for sure what this came out of, here are front pad numbers, I can't see the back pad casting numbers yet.
TO202CTB 12J209360, it looks like it has a factory high rise intake on it. It has a spun bearing previous owner said. Any idea what its worth? Thanks for any help, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Re: Big block motor gurus, info help???
CTB is 1972 car full size, 402 & 396, manual or auto, 210 & 240 HP. What is the casting number of the intake?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Engine assembly plant breakout
T Tonawanda engine assembly plant O2 February 02 2nd day of February CTB 1972 Camaro, Chevelle 396/402 (240hp) LS3 w/Air Injection w/TH auto trans or 1972 Chevrolet (full size car) 396/402 (210hp) LS3 w/Air Injection w/manual trans VIN breakout 1 Chevrolet (car line) 2 1972 J Janesville assembly plant 209360 vehicle serial number
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 07-30-2013 at 04:12 PM. |
Thanks guys, Here is intake number 3883948. It has a turbo 400 behind it now
That manifold was used on most Chevy full sized cars, Cevelle, Vettes, El Caminos, Novas, Camaros, from 1966-69. Quarda Jet manifold, in real nice shape you can get upwards of $200 bucks.
Thanks for the info Lee, I'll be selling it if you know anyone wanting one. Randy
Last question how do I find what horsepower it has? Thanks for the help. Randy
The HP rating was a dressed, installed number. The longblock was the same for both numbers. At this point you need to remember with an incorrect intake all bets are off until proven otherwise. Might pull the intake and find a casting date so you know what year it is. As to the long block ID the head casting numbers and date codes. If they are correct they may be original to the block. Roll it over and check the crank too. If you have the exhaust manifolds with AIR fittings, look up those casting numbers and dates.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
OK here are all the numbers I can find on this
more
mor
mo
454 heads on a 396 or 402 block...
1970 CHEVY SWB 454BBC TH350 |
Like I thought ("...all bets are off until proven otherwise") a collection. The good news is they are all external parts and the short block might be an intact, grouped LS3 assembly from 72.
But to determine that you will need the crank rod and cam numbers. Block 39999290 72 402 240hp 2 bolt GM10T HI PERF PASS F9 Heads 336781 73-85 454 oval port 113cc J23 73 Oct.23, 1973 L10 76 Dec.10,1976 GM9T Exhaust 14045176 RH 67-87 396/454 truck 3994045 LH 73-75 454 police
#15 |
![]() Join Date: Feb 2003
WOW! You guys are GOOD!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#16 |
Thanks Dave, Especially for the price right?
Need to dig for it but somewhere I might still have the block numbers off your truck verifying it was a correct L47/NE2.
#17 |
Florida Edition
![]() ![]() Join Date: Oct 2010
These guys are not only good, they might be the best. They make this forum amazing.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#18 |
THANKS GUYS for your help, it is VERY much appreciated!!!!!!!
