Old 08-04-2013, 12:23 PM   #1
PatrickGMC70
PatrickGMC70's Avatar
Paper gasket or silicone for water pump?
I'm in the process of tracking down a S - L - O - W coolant leak on my truck. Everything is new, which is why this is particularly frustrating. Long sorry short, I was getting tired of the drain, fix, refill, still leaking approach, so the water pump is now off. (I'd thought it may have been a slow leak from the back cover of the pump.)
In mounting the pump back to the block, I have a set of the paper/cardboard gaskets, and which I used originally. But I was wondering if these are a weak link, or if they're a tried and true way of sealing this spot. So before I threw it back together, I thought I'd ask whether there's a consensus about using the standard gaskets or gray silicone (or both). When I took the pump off, the gaskets were wet, but I'm assuming that was just from the process of taking it out and the coolant that was behind the pump.
The only good news is that after all of this, my problem should be solved (unless I put something back together wrong) because everything else has been checked and rechecked.
Thanks!
Patrick
PatrickGMC70 is offline   Reply With Quote
Old 08-04-2013, 01:02 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Paper gasket or silicone for water pump?
My personal preference is use both. I coat both sides of the gasket's with sealer and install.
Now for the ? of the leak. Do u run a recovery tank? If not I suggest u start and if not then where is your water level at when the truck is cold? if it's to high in the radaitor then it will boil out and the cold level will be less the next time u check it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-04-2013, 01:52 PM   #3
vidman
vidman's Avatar
I would use the gasket and a sealant. I have been using Edelbrocks gasgacinch for a while with great results..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 08-04-2013, 03:45 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Paper gaskets with a little dab of Permatex #2 or Hondabond or similar glue is all you need.
There is no need for silicone under any circumstances. There's exactly two places to use silicone on a Chevy V8 engine, at the ends of the intake manifold and at the corners of the oil pan gaskets.
As long as you get the surfaces clean with a razor blade or gasket scraper and use proper torque procedures you will be fine.
Tx Firefighter is offline   Reply With Quote
Old 08-04-2013, 03:51 PM   #5
1972RedNeck
1972RedNeck's Avatar
I don't use any water pump/timing cover/valve cover/oil pan (etc.) gaskets at all. It is all grey silicone.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-04-2013, 04:02 PM   #6
PatrickGMC70
Thanks everyone.
It really was a small slow leak - about 2-3 drops per min or so. It was coming from somewhere near the pump, and I'd already checked the lower radiator hose, heater hose, heater hose nipple, & even replaced and added sealer to the mounting bolts. Then in between each "fix" I had to wipe down everything - crossmember etc - to make sure it was still a leak and not just residue.
I'm sure taking the pump off wasn't the most logical or rational step, but I was just so disgusted and frustrated with this leak that it was halfway off before I knew it. Hopefully, this will be the last time for a very long time!
Old 08-04-2013, 04:08 PM   #7
PatrickGMC70
Thanks. I don't have a recovery tank (yet) but it wasn't leaking at the drip hose. It was coming from the water pump in the front on the engine. BTW, it's pretty scarry sitting under a running truck with that fan spinning right above you looking for where the leak is coming from.
The recovery tank is definitely on my short list of projects to get done.
Old 08-04-2013, 04:46 PM   #8
Lee H
Lee H's Avatar
The lower right water pump bolt goes into the water jacket and needs sealed, or it will leak.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-04-2013, 04:50 PM   #9
PatrickGMC70
Thanks Lee - I wasn't taking any chances though. I put sealer on all 4 bolts. This leak will die!
Old 08-04-2013, 05:53 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Originally Posted by Tx Firefighter View Post
Paper gaskets with a little dab of Permatex #2 ...... is all you need.
x2..... no silicone, I've seen it leak too often.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-04-2013, 06:34 PM   #11
GRX
GRX's Avatar
Paper with a thin film of #2 or Aviation Permatex 'form a gasket'.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-04-2013, 08:17 PM   #12
MLB57
Use a anaerobic gasket maker. Will fill a .010 gap and will never leak, use your paper gasket it with it. I have mounted water pumps with no gasket and never had a problem
MLB57 is offline   Reply With Quote
