Old 08-07-2013, 06:52 PM   #1
wesmigletz
wesmigletz's Avatar
What M/T parts/linkages need changed when going from an in-line 6 to a V8?
I pulled the 6 from my 67 and bolted in a small block at the V8 location using V8 mounts. Looking at the engine bay, it looks like I will be better off using the 6 cyl mounting position.
I would like to re-use as many of the 6 cylinder components as possible and keep the three on the tree.
Is the Z bar the only component that needs changed when going from a 6 to a 8? If I move to the 6 cyl position do I use the V8 or 6 cyl frame mounts?
Thanks,
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 08-07-2013, 10:44 PM   #2
70cst
70cst's Avatar
Re: What M/T parts/linkages need changed when going from an in-line 6 to a V8?
I don't know but here is a bump for you ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-07-2013, 10:51 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
Thanks,
Wes
You can mount a V8 in the 6 position, but it makes running an HEI distributor almost impossible to run with beating in the firewall.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-07-2013, 11:17 PM   #4
Legolas894
Chemist under the hood...
Legolas894's Avatar
My 283 is set up on the I6 mounts.
You will find it cramped for the distributor, rear plugs etc.
You will need an extension to mount the fan to the fan pulley since it sits back so far from the rad. The rad shroud may or may not work.
I had issues with the 4-speed shifter linkages hitting the e-brake cable stuff. Some clearance issues as well. The big advantage is that you don't have to change your driveline.
You will need all new bracketry for alternator and any other accessories. Carb set up will be different (linkage to gas pedal and choke etc).
Still worth doing but if I could do it again, I would put it on the V8 mounts just to have the room.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 08-08-2013, 12:32 AM   #5
wreckedchevy
wreckedchevy's Avatar
I used the I6 stands and the I6 position for my 305 i'm running stock GM hei had to give the firewall a few love taps can't really tell unless the distributor is out. if your running standard I think you'll need the ball that screw's into the block and I don't remember if I used same clutch linkage or if I robbed the one out of my stock v8 parts truck.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 08-08-2013, 01:12 AM   #6
wesmigletz
wesmigletz's Avatar
Thanks for all the replies.
If I used the 6 cyl position, I would stick with a points distributor. I really don't want the fire wall clearance hassle. Hate to think about pulling the cap on the side of the road to replace a module.
Any idea if the Z bar or bracket that bolts to the block is different?
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 08-08-2013, 01:53 AM   #7
wreckedchevy
that's the part I can't remember if I took it off my factory v8 truck or if used the I6 one here's a couple pic's hope it helps
Old 08-08-2013, 01:56 AM   #8
wreckedchevy
I've gotten over 200,000 miles on mine most of them weren't very kind miles on the lovely back roads of Montana with no issues ever. bought a used distributor put new cap/rotor/coil on it and it's never been changed since(probably should do that someday)
