Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-08-2013, 11:42 AM   #1101
Dale99
Re: Junkyard Jimmy Super Low Buck Build Thread
For blotchy, do as mentioned. But also keep the most constant speed you can.
Agree about the looking under fenders. Missed a spot on my last primer job, DOH!!
Dale99 is offline   Reply With Quote
Old 08-08-2013, 05:46 PM   #1102
hgs_notes
GEARHEAD
hgs_notes's Avatar
Originally Posted by Low Elco View Post
The trick is, it's a lot like clearing. Turn your air pressure up a bit (you have a gun mounted regulator, right?), turn your fan as big as it'll go, and stay a bit farther off. Your first round should barely cover and be blotchy. Id go 3-4 rounds, and alternate directions between them. go <> then up-down, esp. on the hood. Id go straight, then 45 deg on the sides. Uniformity is important, mind your overlaps. Most importantly, DON"T STOP. It's like clear, if you pause you get a run or blob or sag, if you do it with this, you get a blotch. Even if you know you messed up, don't stop, you can always fix it on the next round. But mostly relax. Keep telling yourself, it's just paint. Not even expensive paint. It's just paint. Relax and enjoy the process. get out the lights and make sure its good before you clear it. It'll be fine.
Thanks again. I have a habit of laying it too heavy so I will be sure to turn the flow down and spread the fan. Maybe this technique will reduce the orange peel I've been getting too. I've found that spraying the clear I have better results with heavy coats and more orange peel if its light, but I risk runs. That doesn't bother me too much on the clear though cause I can cut it down, sand it out and polish it.
I hear ya. I noticed that when I was spraying primer and getting the bottom edge of the rockers, bed sides and fenders. Was always lighter there. But it's easier to get those on the Jimmy cause its a bit higher than my C-10, where I had the hose rubbing the floor as I moved along.
I took vacation for tomorrow, so I have from tonight until next Monday to mess with it. Then I have to leave for Omaha for work on Tuesday. Time to do more cleaning and taping.
hgs_notes is offline   Reply With Quote
Old 08-08-2013, 05:48 PM   #1103
hgs_notes
GEARHEAD
hgs_notes's Avatar
For Bomp...
Old 08-08-2013, 05:51 PM   #1104
hgs_notes
GEARHEAD
hgs_notes's Avatar
And 1 for me, most songs hook you with a guitar riff, this one hooked me with the drums....
Old 08-08-2013, 08:45 PM   #1105
Low Elco
Let 'er rip, Tater Chip!
Low Elco is offline   Reply With Quote
Old 08-09-2013, 10:59 AM   #1106
hgs_notes
GEARHEAD
hgs_notes's Avatar
Might not be getting sprayed this weekend now. Their dad is going to use the booth this weekend and they said I might be able to get it in next week, during the day if they don't have to use it. Dammit!
Old 08-09-2013, 11:03 AM   #1107
Bomp
Bomp's Avatar
Sorry to hear about the set back.
Killer vids though man!
Gotta look on the bright side, More time to look for another project.
Bomp is offline   Reply With Quote
Old 08-09-2013, 12:24 PM   #1108
hgs_notes
GEARHEAD
hgs_notes's Avatar
Riiiiiight. Another project.
Like this one?
With a bed like this maybe...
Old 08-09-2013, 01:10 PM   #1109
Dale99
I was thinking time to check again to make sure all the body work is done.
Old 08-09-2013, 04:54 PM   #1110
hgs_notes
GEARHEAD
hgs_notes's Avatar
Man, that's just mean.
Old 08-09-2013, 05:37 PM   #1111
Dale99
no, its just easy to forget stuff when your on a project that long
Old 08-09-2013, 05:59 PM   #1112
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
He's moving faster than 90% of the people on this board.
Ryan
1969 Chevy milk truck
Old 08-09-2013, 09:42 PM   #1113
hgs_notes
GEARHEAD
hgs_notes's Avatar
I knew what you meant, but it was a good set up for me. And I can't remember what I did with the drive arm for the wipers. Sheesh. I've been over this thing so many times that the flaws are known and acceptable to me or will be fixed during the spraying.
Maybe, but feels like a snails pace to me getting the body and paint done.
Friend from the body shop came by so I could see if I was taping it up right. I wasn't. Had to pull off about half of what I had done because I was too close to the edges. He said to stay away from the edges or it can peel the paint off with the tape in an area that will require a repaint. I looked at how they taped my truck ( Why the hell didn't I think of that before) and now I know better. Most of that is fixed, just need to correct the driver side door area. He said I should try to cover the underside of the hood too, which is gonna be a bit of a PITA. But overall he said it was ok and gave me tips for the rest of it.
Since I'm not painting I think I'm gonna get in some fishing this weekend. The boat is running good now and I don't have many days before the weather gets uncooperative to be out on the water. I went last weekend just to check out the motor and get some worms wet. I caught about 10 fish, all to small to bother cleaning. My youngest likes to fish and we need some fresh stuff to fry up.
Old 08-10-2013, 09:50 AM   #1114
hgs_notes
GEARHEAD
hgs_notes's Avatar
back on post #936 you gave me some hitch info. I finally got that exact hitch. I was wondering if you could get me some pics of how its mounted to your frame, and maybe some hole dimensions referenced from some spot on the frame?
Heres some pics of my hitch and how I installed it. First the side plates are reversed from side to side and 1/2" plates with holes drilled to match where the side plates bolt to the cross piece are used as spacers to get the side to side distance correct.
The hitch came with some 1/2" thick re-inforcement parts, but I used them as spacers between the hitch and frame, then had other re-inforcement plates to use on the other side of the frame for added strength. The side views of the hitch show it good. I can't remember what holes I had to drill, if any.
This is no way close to how the manufacturer recommends installing this hitch. I used what I had available and did the best I could to make it work. It's a class 3 hitch and I used this same set up (minus the spacers between the frame and hitch) on my C-10 for a few years to pull a 20" Four Winns open bow run about with inboard/outboard. The boat itself weighed over 3000# I think. Never had any issues and my frame rails on the C-10 looked just fine after I removed the hitch.
I have no intention of ever towing something that heavy with the Jimmy, but I wouldn't be scared to if I did. Hope this helps.
Old 08-10-2013, 09:51 AM   #1115
hgs_notes
GEARHEAD
hgs_notes's Avatar
As for a Jimmy update, I did more taping.
That is all.
Go about your business.
Old 08-10-2013, 05:06 PM   #1116
Dale99
Thanks for the pictures. I was out test fitting it about the time you posted them. I now see a few things that I wasnt figuring out when test fitting.
Old 08-12-2013, 08:55 AM   #1117
Low Elco
Catch any fish?
Old 08-12-2013, 09:51 AM   #1118
hgs_notes
GEARHEAD
hgs_notes's Avatar
Glad I could help.
Catch any fish?
Yes I did. I got 3 crappies, a large perch and a bullhead. Didn't keep the bullhead. Ick. It was a nice calm day out on the water.
I have almost all the taping done that I can do before I get in the booth. Except for an adjustment to make on the driver door edges anyway. I wiped it all down with wax/grease remover this morning and have some paint prep stuff to use before I spray it that is a milder solvent and flashes off better. I'm heading to Fremont, NE tonight and home late tomorrow. Will figure out when I can get in the booth after that.
Old 08-12-2013, 12:31 PM   #1119
jaros44sr
jaros44sr's Avatar
How about 99.9% , he!! of alot of progress going on, and quality work to boot. Well done on the work....hope things get better with the wifey, prayers go out
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-13-2013, 09:03 AM   #1120
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks, I appreciate the kind words, but I doubt I'm in the top .1% for rate of progress. Whens the start date on this again?
BTW, Looks like you have been taking remedial courses at sensitivity school. (signature)
I stopped by the body shop on my way out of town yesterday and I was told the paint booth is mine tomorrow. Fingers crossed. Working all day here in NE, then a 5 hour drive home tonite, so I won't know for sure til tomorrow morning, but it looks good. I will have both brothers there for support and advice all day too, which helps ease my mind. Worst case is I will have to do some sanding and respray. It's not like I'm going to break anything.
I better put in for a day off before I forget.
Old 08-13-2013, 09:58 AM   #1121
jaros44sr
jaros44sr's Avatar
Yeah, i guess i have to change the siggy, after finding out ive had 4 strokes, kinda made me think i need an attitude adjustment. The whole situation of health, just made me rethink things....im not as tough as i once was
Progress and build time are differant topics, seems to me your always doing something.
Good luck in the booth, hope it all works out for you
SAFETY FIRST
AS usual, off topic
Jim
Old 08-13-2013, 11:16 AM   #1122
Low Elco
WooooooHoooooooo! Time to load up and rock and roll, Boys! Good luck, and send us some in progress shots!
Old 08-13-2013, 12:16 PM   #1123
71swb4x4
71swb4x4's Avatar
Go Mike! I hope it all goes well.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-14-2013, 09:21 AM   #1124
hgs_notes
GEARHEAD
hgs_notes's Avatar
Sorry fellas. Not today. Maybe tomorrow. Probably tomorrow. They got a business to run and yesterday afternoon a customer wanted something done today that they need the booth for. Paying customers take priority.
Old 08-15-2013, 12:37 PM   #1125
hgs_notes
GEARHEAD
hgs_notes's Avatar
Its time to spray.
