11-02-2003, 01:24 PM | #1 |
Born Psycho
gov-loc limited slip for sale
for a 10 bolt, 8 1/2 inch rear differential. came out of a 95 suburban 4x4 with 3:73 gears. it worked fine, we swapped over to an eaton posi unit for a customer at work.
$30.00 plus shipping. <<SOLD>>
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA Last edited by jerry moss; 12-14-2003 at 02:04 AM. |
11-15-2003, 11:54 PM | #2 |
Hello Jerry,
Would that unit fit my 90 GMC Sierra 4x4 with the Z71 Offroad Package? I'm not sure what I have in there now, just got the truck for my son, any way of telling from the VIN # what ratio is in there and if it's a posi? Thanks, 72 |
11-16-2003, 12:48 AM | #3 |
Born Psycho
72,
if you pull the vin and give it to your local dealer they can tell you what you have in there.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
11-16-2003, 02:19 PM | #4 |
Jerry,
I will do that monday morning, but still need to know if that Gov-Lock is the right one for my housing? What's the difference Between a Gov-Lock, and a Posi? Is it better than an open rear? How does it compare to a Limited Slip rear? What ratios will that 3.73 carrier accomodate, lower and higher? Thanks Jerry, 72longbed |
11-16-2003, 09:28 PM | #5 |
In my signature you'll see a link for GM RPO Codes. If you still got the sticker in the glove box, look up all the RPO codes on there and it will tell you the gear ratios and alot of other information about the truck.
GM RPO Codes '95 K1500 4x4 Ext Cab 5.7 TBI NV4500 Tranny, 14 Bolt swapped in, locker, 3.73's |
11-16-2003, 10:23 PM | #6 |
Thanks cedjr.,
Great Info!! 72 |
11-17-2003, 09:45 PM | #7 |
Boosted Member
Well, off the top of my head, this WILL be a direct bolt in to your truck if you have G80 and GT4 in your glove box. G80 is the gov-lock, and GT4 is the RPO for 3.73s.
A good resource for all sorts of late model info is the message board at www.fullsizechevy.com
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-03-2003, 04:02 AM | #8 |
Will race for cash
have you sold it yet? if not i want it
92 chevy stepper,4-bolt flat top 350, Aeromotive carb bypass regulator, holley 650 dbl pumper ,edelbrock performer intake, .530 .545 hyd bump stick, 3/8 sis, guideplates, 2.02 1.60 manley valves,tci street fighter t350 b&m 2500 stall, 3.73 richmond |
