Old 08-08-2013, 10:06 PM   #1
Thebrownturd
Hood alignment
I can't seem to get the hood to sit right. The hood closes good but, the back is to high and on the passenger side the hood has a millimeter of space. I have tried and tried to adjust and even tried to move the radiator support and it still won't fit right what ave some of you guys done that has worked
Thebrownturd is offline   Reply With Quote
Old 08-08-2013, 10:11 PM   #2
muckyp
muckyp's Avatar
Re: Hood alignment
Is it an after market hood or original hood?
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 08-08-2013, 10:20 PM   #3
beetle1960
beetle1960's Avatar
Re: Hood alignment
If the back is high, open the hood fully, loosen the front and the rear lower hinge bolt (the ones that attach to the fender) now push up on the front of the hood, this will rock the front of the hinge up, hold it up and tighten bolts. This will lower the rear of the hood, may need to adjust a couple times to get it right.
beetle1960 is offline   Reply With Quote
Old 08-08-2013, 10:29 PM   #4
Thebrownturd
Re: Hood alignment
It is an origianal
Old 08-09-2013, 09:46 AM   #5
SuperC10Tex
SuperC10Tex's Avatar
Re: Hood alignment
^^^^^This man is correct!!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 08-09-2013, 10:02 AM   #6
slow-1
slow-1's Avatar
Re: Hood alignment
Don't give up.
I am sure that guys who align hoods all the time can get it done quick, but it took me and my buddy about 20 tries to get mine close after the hood was off and the hinges were removed, cleaned, painted, and put back on.
The trouble was that the up and down adjustment also moves it front to back requiring a front to back adjustment.
If you could get someone small enough to be inside with the hood closed it would work perfect.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-09-2013, 03:20 PM   #7
davischevy
davischevy's Avatar
Re: Hood alignment
What they said.
davischevy is offline   Reply With Quote
Old 08-09-2013, 06:26 PM   #8
beetle1960
beetle1960's Avatar
Re: Hood alignment
good article on panel alignment..General rule of thumb is to align the doors to the body first, then fenders to doors, then hood. But of coarse never goes like it should...can get frustrating.
http://www.autobody101.com/content/a...nel-alignment/
Old 08-09-2013, 08:04 PM   #9
Sklptrljay
Sklptrljay's Avatar
Re: Hood alignment
Side to side can be altered by adjusting the hood pin bracket (attached to the hood) instead of fighting the bracket on the radiator support.
Sklptrljay is offline   Reply With Quote
Old 08-10-2013, 09:34 AM   #10
BLACKLINE61
BLACKLINE61's Avatar
Re: Hood alignment
I've had good luck with replacing the worn out hinges to fix the alignment issue you are having, if there is any side play in the hinges at all the springs won't pull the hood down properly when closed, I'd check that first before shifting body panels around!
BLACKLINE61 is offline   Reply With Quote
