Old 12-03-2003, 09:53 AM   #26
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
They...
are halo lights I bought off ebay. They have the WhiteHot bulbs and the also have 2-194 bulbs that you can hook up on a different circuit. You can change the color of the bulbs to change the color of the ring. These were copied off the newer BMW which have this as a stock option. The only installation problem is that you have to cut the headlight bucket out some to clear the 194 bulb housings. Also, wire in a headlight relay to take the load off the headlight switch. These babies get hot. I have the halo section hooked up to the ingnition switch on my truck. So, when the key is on, the halo's are on. Here's a pic. BTW, I think I paid $50-60 for the pair, not bad. Go to ebay and search for "67 Camaro Halo Lights". It should come right up.
Landon, it is coming along but as I stated in a different thread, I am now looking at the expensive part of this LT1/4L60E install. The wiring harness and computer re-burn. I'll get over the shellshock soon enough. Later, FCG
FuelCellGuy is offline   Reply With Quote
