Old 12-02-2003, 02:44 AM   #1
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Speed Warning Dash
DOES ANYONE HAVE ANY KNOWLEGE ABOUT A SPEED WARNING DASH OR HAVE SOME LITRATURE ON THESE. I AM BUILDING ONE AND AM IN THE DARK ON THESE BECAUSE I HAVE NEVER BUILT ONE ,I HAVE BUILT MANY TACH DASHES BUT NEVER A SPEED WARNING DASH. THANKS FOR YOUR HELP 67-72
PT'S 70 CST is offline   Reply With Quote
Old 12-02-2003, 02:50 AM   #2
Smokin72on20s
Ebay Junky
Smokin72on20s's Avatar
what is a speed warning dashs purpose? what the hell is it?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain..
1983 Chevy c10 swb 2wd - possible 350tbi supercharged...
Smokin72on20s is offline   Reply With Quote
Old 12-02-2003, 02:59 AM   #3
PT'S 70 CST
"GO DAWGS"
IT IS A DASH WITH A NEEDLE YOU SET ON A CERTAIN MILE PER HOUR AND WHEN YOU REACH THAT MILE PER HOUR IT GIVES A NOISE TO LET YOU KNOW HOW FAST YOU ARE GOING. THEY WERE MOSTLY USED IN MEDIUM DUTY TRUCKS 30-60 SERIES AND IT IS A VERY RARE OPTION.
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
Old 12-02-2003, 08:13 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I don't know much about them...the buzzer mounts up under the dash...they are extreemly annoying...and they were not an option in 70 if memory serves. I think 69 was the last year.
Old 12-02-2003, 10:34 AM   #5
Huck
Huck's Avatar
They were a pretty common option on cars in the 60's--buicks, olds, pontiac, etc. Truck units typically sell for $150 & up depending on what else is in the dash cluster (Tach, Vac, Air Pressure) and of course condition. Believe Andy is right that 69 may have been the last year offered as an option.
Huck is offline   Reply With Quote
Old 12-02-2003, 10:59 AM   #6
spencra
This, is my BOOMSTICK!
spencra's Avatar
Thanks for the info on the speed warning. It was bugging me that I couldn't figure out what that was.
I can sleep better at night now
spencra is offline   Reply With Quote
Old 12-02-2003, 11:35 AM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Question
i'm getting ready to reassemble 3 of them that i had punched for tachs, 2 will be tach,vacuum, & speedwarning and one just tach & speedwarning. i don't have any pics or literature on them but i believe longhorn man is correct about 69 being the last year it was offered.
i'm curious about your statement about them being used mostly in 30-60 series trucks. i've owned several speedwarning clusters over the past 20+ years but i've never seen one in anything other than pickups and suburbans. have you personally seen them in the bigger trucks ? if so, i'm going to kick myself in the butt, i always give the bigger trucks a quick glance for tach and/or vacuum and walk away.
i'm not sure if i can answer your question about your cluster but i'll p.m. you my phone number
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-02-2003, 12:11 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
I can add a logical reasoning to support this, though I can't verify based on actual experience. Allow me to state my hypothesis
1. Speedwarnings are designed to buzz when a preset speed is exceeded. That is the premise for having one.
2. The are annoying by design.
3. Who would benefit from this premise/design better than sites where speed sensitivity is a safety issue (construction sites, airports, etc).
4. heavy duty trucks would be more predomanent in such sites.
5. It would be very easy to preset them, then remove the needle set knob so the setting could not be overridden easily.
6. The cluster design for series 10-30 and 40-60 are essentially the same so a speedwarning would be a no R&D option cost.
Jerry, I suggest you may want to take a double take at those bigger rigs.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 12-02-2003, 12:52 PM   #9
smonty
Smonty
Speedwarning
The speed warning has a wiring harness that goes from the speedometer/circuit board to the buzzer. There is a cable w/knob on it to set the speed you want the warning set at, and the buzzer. You have to drill a hole in the bezel to mount the adjusting knob. That is about all that is to them. The problem is usually not the speedometer it is finding the rest of the parts. Hope this helps a little. If you have a truck later than 69 it would be a little out of place as the option was not offered on trucks after that. I just sold a nice restored speedwarning, tach, vacuum guage cluster as it would not look right on my 71. All the ones I have found were on 68 model trucks. This must be the year that most of them were installed. I am going to start giving the bigger trucks a better look from now on as I never thought they would be installed in them. It was always like Xmas when I found just a tach dash in one.
Ernie
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
2005 Chevy 1500HD Crewcab
56 Chris Craft Mahogany Runabout
Looking for 36 Chevy 1/2 Ton P/U Project
smonty is offline   Reply With Quote
Old 12-02-2003, 01:21 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Speedwarning
Ernie, I'm only making a logical guess here. If someone has some definative proof one way or the other, I'd like to see it. Life has taught me that what seems logical, often isn't the case.
Old 12-02-2003, 01:57 PM   #11
smonty
Smonty
Reply to CPNE
I will be positive and hope that I can find a speedwarning, tach,air pressure guage dash at a yard somewhere for $50.00.
Now, THAT would be Xmas!!
Take care,
Ernie
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
Old 12-02-2003, 08:20 PM   #12
PT'S 70 CST
"GO DAWGS"
I HAVE PERSONALLY SEEN ONE IN A 40 SERIES TRUCK AND JUST ASSUMED THAT THEY WOULD MOSTLY COME IN BIGGER TRUCKS. THE ONE THAT I HAVE WAS A 69 BECAUSE THAT IS WHAT IS PRINTED ON THE BACK OF THE CIRCUIT BOARD. AND I ALSO WANT TO KNOW WHAT IS THE MAIN PURPOSE OF AN AIR PRESSURE GAUGE, I WAS UNDER THE IMPRESSION THAT IT WOULD HAVE BEEN USED ON BIG TRUCKS BECAUSE MOST OF THE DASHES THAT I HAVE PULLED OUT OF BIG TRUCKS HAD OVERSPEED AND ? ON THE FUEL GAUGE WERE MOST 10-20 SERIES HAVE BRAKE AND TEMP. THANKS FOR ALL OF YOUR REPLIES. MINE IS A SPEED WARNING, TACH, AIR PRESSURE DASH.
70 CST SWB
70 NOVA
2000 Silverado swb
29006
Old 12-02-2003, 09:16 PM   #13
Don Loverink
Hi from Minnesota, if anyone has an extra speedwarning setup for sale, let me know, I just bought another project and I need a speedwarning for it. thanks, don
Don Loverink is offline   Reply With Quote
Old 12-03-2003, 11:19 AM   #14
smonty
Smonty
Reply to PT'S 70 CST
Yours is the first one I have seen coming out of a big truck. There is hope! The air pressure gauge is mainly for the air brake system in the truck. Air pressure actuates the trailer brakes. If the truck has spring-powered emergency/parking brakes on it or is hauling a trailer w/spring emergency/parking brakes on it then the driver would want to know if he is loosing air pressure. When the air pressure gets below around 60psi the brakes set. Not a good thing if you are trucking down the road. That is what I would be using the gauge for.
Ernie
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
Old 12-03-2003, 11:27 AM   #15
jerry moss
Born Psycho
jerry moss's Avatar
i'll be looking a lot closer at the bigger trucks from now on.
jerry moss
