Old 08-11-2013, 02:45 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Chevy and GMC differences
I am looking at a 1972 GMC Sierra Grande long wheelbase very seriously and I'm wondering if the GMC will ride rougher/harsher because of the leaf spring rear as opposed to the Chevys trailing arms. I've had my long wheelbase Chevy up to near 100 mph and it was steady and solid on the road and rides real smooth. Would the leaf spring GMC be the same? I guess ideally if anyone has had both Chevys and GMC's and drove them both for a while that should answer my question.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 08-11-2013, 08:27 AM   #2
Eddie H.
Eddie H.'s Avatar
Re: Chevy and GMC differences
I have never been able to tell much difference in the ride between trucks with trailing arms or leafs. I prefer GMC just because of the look of the front end, otherwise they are basically the same truck.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-11-2013, 08:57 AM   #3
Either make could have leaf or coil,but coils certainly ride best...sifter...in an empty truck. Leaf springs are certainly steady at high speeds and you get less body roll. If you've ever driven either a Chevy or GMC made after '72,that is how these ride with leaf springs
Old 08-11-2013, 10:29 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Depends on what you prefer. My 68 GMC has leaf springs and my no longer running 69 Chevy had coil springs. Both were swb and the coil springs were somewhat smoother. I'm not sure how the lwb compares but I would suspect both may run smoother than the swb.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-11-2013, 01:49 PM   #5
Already Gone
Thanks for the info. Sounds like there isn't much if any difference. The reason I ask is that I plan to use it as daily driver in the summer and want a reasonably smooth ride like I get with my Chevy.
Old 08-11-2013, 01:58 PM   #6
Chrome8
Chrome8's Avatar
Does anyone know if there is a difference in the rear view mirrors on GMC's? Mine is partially missing so I pulled the mirror out of my 69 chevy and it is very different than what's left of the mirror in the 69 GMC. Any thoughts? Not a hijack just a chev gmc question.
1969 K20 not running, complete but rusty with wrecker boom and push bumper
1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina"
1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed
"Choose a job you love, and you will never have to work a day in your life."
Confucius
Chrome8 is offline   Reply With Quote
Old 08-11-2013, 03:42 PM   #7
68gmsee
Active Member
68gmsee's Avatar
I have the original round peep mirrors on my 68 GMC and 69 Chevy and they're the same. There were several aftermarket mirrors made and even the dealer could install whatever you wanted on them. There is a difference between the right and left one, though.
06 Trailblazer
Old 08-11-2013, 05:17 PM   #8
Chrome8
Chrome8's Avatar
Sorry man, I didn't mention that I was working on the inside rearview mirror.
Confucius
Old 08-11-2013, 06:40 PM   #9
68gmsee
Active Member
68gmsee's Avatar
In that case I don't know. However, I do know that some didn't come with a mirror and the dealer would install them. After market mirrors could still be the difference in what you see.
I would start a new thread and post some pics so we can see what you got.
06 Trailblazer
Old 08-11-2013, 06:43 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Leaf springs will have a rougher ride than coil springs, unless you are carrying a load in the back.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-11-2013, 08:25 PM   #11
SS Tim
SS Tim's Avatar
THey will ride differently but not a huge difference. Of course if it has HD springs (G50) too, then it will be stiffer yet.
Funny thing is the base rate leaf spring option (G70) is 17lbs lighter than the coils on a lwb 10/1500. There is even more difference on a swb.
Overhung weight will also affect the empty ride.
A standard rear bumper adds 56lb to the rear axle weight while pulling 16lb off the front.
The factory step bumper adds 96lb to the rear axle weight while pulling 27lb off the front.
Any spare tire helps under the rear as would a receiver hitch.
Even a wood bed is good for another 11lb on the rear axle.
SS Tim is offline   Reply With Quote
