Old 08-10-2013, 05:51 PM   #1
In The Ten Ring
Brake drum assembly question.
It's like everyday I need to ask ya'll something!
I tore down the driver's side (rear) drum and brake assembly, used my dremel tool's wire wheel to clean off all the rust (a lot of it) but the little geared wheel on my adjuster/pivot nut WILL NOT TURN. The Haynes book I bought suggested replacing it. Naturally Advance Auto has never heard of it for that year (rather like the radiator you guys suggested and I bought from them).
Anyone have an Advance Auto part number for me? Should I just soak this thing in something?
Here's a pic, if I get it to work.
(Oh yes, I wore a mask and goggles for the brake cleaning)
http://i1313.photobucket.com/albums/...ps4828e6a8.jpg
Oh, and I could not for the life of me disconnect the parking brake from the actuator so I just cleaned the actuator as it hung there. Is that normal?
In The Ten Ring is offline   Reply With Quote
Old 08-10-2013, 05:56 PM   #2
Lattimer
Lattimer's Avatar
Re: Brake drum assembly question.
Can't speak for Advance, but I know both Napa and Autozone carry them. They are left and right specific.
I prefer to replace them, as they will lock up again pretty quickly once they have some corrosion in them.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-10-2013, 05:57 PM   #3
Lattimer
Lattimer's Avatar
here is how I buy them with the kit:
http://www.autozone.com/autozone/par...6_150010_2362_
Shawn
Old 08-10-2013, 06:08 PM   #4
In The Ten Ring
Thanks man! I just called NAPA and they're going to order both adjuster assemblies and set both sets of spring kits aside for me.
My springs were still serviceable I'm sure but they were pretty rusty.
I think my shoes looked pretty good....but seeing as I've never seen a set of brake shoes before I am not be the best judge!
Now if I can just get everything back together!
Would it be a good idea to go ahead and flush out the old brake fluid? If so, what is a good 1-man kit to do that with?
Old 08-10-2013, 06:38 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Here you go...
http://www.pbase.com/nufsed/drumbrake
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-10-2013, 07:08 PM   #6
Lattimer
Lattimer's Avatar
I have a MityVac that works well. Got that at Harbor Freight, but seen them other places too. Definitely a good idea to swap out the fluid, it can get water in it over time.
Shawn
Old 08-10-2013, 07:24 PM   #7
jd7
jd7's Avatar
Nice kit, great advice
jd7 is offline   Reply With Quote
Old 08-10-2013, 07:54 PM   #8
geezer#99
geezer#99's Avatar
Here's a trick for removing the park brake cable from the backing plate. Use a small hose clamp, open it up, slide it over the cable and over the little tangs where the cable comes thru the plate. Tighten it enough to collapse the tangs and the cable slides right out.
geezer#99 is online now   Reply With Quote
Old 08-11-2013, 01:59 AM   #9
franken
The wide gear looking bit in the pic is the star wheel. I'd leave the whole thing in oil/atf or something (not WD40) overnight and it will free up.
BTW, the purpose of that thing is the autoadjuster so when you back up and stop, it adjusts the shoe out if needed to keep the brake pedal high.
Or at least that's how I think it works. If I'm full of crap, I'd appreciate being set straight. Truth trumps pride (or whatever)?
franken is online now   Reply With Quote
Old 08-11-2013, 09:15 AM   #10
geezer#99
geezer#99's Avatar
You're only half full. Your eyes are brown up to mid level. LOL!!
THe star wheels purpose is primarily to provide a way to adjust the brake shoes from outside the drum thru the access hole in the drum or backing plate.
Second it provides a handy place that the self adjuster arm can contact to keep the shoes adjusted close to the drum.
You can remove the self adjuster but you'll need to manually adjust your brakes to keep the shoes close to the drum.
Some of the first cars I worked on had no self adjusters. Once a month you got out your trusty brake tool (screwdriver) and took out the slack.
Old 08-11-2013, 09:42 AM   #11
gottalottac20
Here is some advice...... AVOID ADVANCE AUTO PARTS!!! go to napa... i bought 6 brake kits 2 hardware and 4 self adjuster kits for 74 bux... advance like you said never heard of them... luckily i have a small family owned napa near my house even bring them coffee sometimes haha
gottalottac20 is offline   Reply With Quote
Old 08-11-2013, 10:10 AM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Here's a bit of advice for what it's worth.When you get those adjusters freed u and cleaned.Assemble them with anti sieze on the threads only.They should stay free and easy to turn for a long time.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-11-2013, 11:53 AM   #13
kcsa75
kcsa75's Avatar
I buy quite a bit from Advance Auto. Most of the time I order online and pick up in the store. Generally, if you spend $25 or $30 there is a promo code out there (Google Advance Auto promo code) that can save you some serious money. If you spend $75 and they don't have it in stock, they will ship for fee.
I have two Advance, two O'Reilly's, two NAPA and a CarQuest distribution center with an attached store within 10 minutes of my house. For the reasons stated above, Advance is my first choice.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 08-11-2013, 03:03 PM   #14
Lattimer
Lattimer's Avatar
I use Advance a lot as well, mostly because its the closest to me. I have Napa, Advance, Auto Zone, and Pep Boys to choose from. A lot of the stuff they sell is the same everywhere.
Shawn
Old 08-11-2013, 05:21 PM   #15
Bigdav160
Bigdav160's Avatar
Originally Posted by leddzepp View Post
Too bad he has the primary (shorter shoe toward the front of the truck) and secondary shoe (goes to the rear) confused.
Also I don't see the lube for the backing plate .
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-11-2013, 05:31 PM   #16
leddzepp
Moderator
leddzepp's Avatar
If you have a better write up and pictures feel free to share
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-11-2013, 05:33 PM   #17
geezer#99
geezer#99's Avatar
I think it's good he has the short in front and the long in back because that's the way it is supposed to be.
Lube on the shoe rests is optional. Some do, some don't.
Old 08-11-2013, 05:41 PM   #18
heyjoe
Yes, Yes, Yes!
Short lining - FRONT
Long lining - REAR
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
